Question about Bravo SD-20 Car DVD Player
Set up Does not work
TV Ears. Have two sets. Why doesn't one set work?
the set that does not work is either defective or not compatible
check the part that plugs in to see if it matches up
Sep 08, 2015 | Lands Phones
Unable 2 get grps settings
Main Menu select > Services > Data Account
set the current GPRS setting properly.
If you sill not able to figure it out you can get the SMS setting from network service provider and you can save the setting so that settings by default account to you.
To make your GPRS working you should first need the settings for it.You cannot set it.Your network provider should give the default gateway address for it.Then only you can use it.
If you already have set the setting and now if it is not working because the network service provider would have changed the gateway Ip address.
Dec 08, 2010 | Dual Electronics CECT P168 Cellular Phone
Sim not working
First, I tried reset the Network settings. This is what I did:
  1. From the main screen, tap Settings.
  2. Tap General.
  3. Scroll down and tap Reset.
  4. Tap Reset Network Settings.
After resetting Network Settings, my phone wass still not working. I then tried to reset all settings.
  2. Tap General.
  4. Tap Reset All Settings.
May 09, 2010 | Apple iPhone 3GS Black (16 GB)
Router settings
Router set up.
Router is not working.
NO CD.
How to set up router.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 11, 2009 | D-Link DIR-615 Wireless Router
Z4M take up spool not working
I loaded defaults, then set it to Rewind, saved settings as Permanent and it worked
Nov 20, 2009 | Zebra Z4M Printer
I have a dual handset GE 2.4 GHZ telephone set. The main hand set works but the second hand set will not work, it just beeps and shuts off.
Swap batteries and see if second hand set will work. Can get new battery or a different hand set on eBay.
Sep 03, 2009 | GE Lands Phones
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Lowest two setting of four settings do not work.
Your posting does not include what settings on what you are referring to
May 04, 2009 | Chevrolet Cavalier Cars & Trucks
Bravo SD-20 Car DVD Player Logo
Top Bravo Car Audio & Video Experts
xxxxxx xxx
Are you a Bravo Car Audio and Video Expert? Answer questions, earn points and help others
