Question about Furniture
Won't stay open
When i lift bed up won't stay up just falls back down?
  • 430 Answers
SOURCE: handle won't stay upright
G3 has a handle return spring. Check to see if it is properly tensioned or broken
Posted on Sep 06, 2009
alicantecoli
  • 22326 Answers
SOURCE: 2005 Porsche Cayenne S
renew the gas filled rams that hold it up
Posted on Jul 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: my sons chain won't stay on and it falls off when
Being a physical problem and lacking any clues about the bike we'll need you to observe and judge what is really happening to make the chain fall off. Use a search engine for "bicycle chain falls off" to get some ideas and guidance on identifying the dysfunction, then the fix(es).
Posted on Aug 09, 2011
SOURCE: The hatch back hatchback door on my hatchback hydunai 2008 accent won't stay open when the door is opened and lifted up, how do you fix this
You might want to replace the two holding levers positioned on the left and right side of the hatchback door.
Posted on Jul 08, 2012
bogo_7
SOURCE: Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Posted on Apr 14, 2014
HappiJac lift bed motor (model#70425-004) drifts down after putting the bed in the up position. Do you have to pin this on the track to keep it from coming down?
The lift bar is attached to motor and it should remain in position when turned off, meaning once you set the position (Height/Angle) it should stay in a fixed position until you make changes. If the MOTOR malfunctions, it could turn forward and backward, but rotate backwards if pressure (Weight) from mattress forces the swing arm backward. This is a condition that needs attention from the bed-frame device manufacturer. You can not fix this problem. If it was purchased from a bed/mattress store; I suggest you go to that store and demand a replacement.
Jan 12, 2018 | Cars & Trucks
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
Jul 08, 2012 | 2007 Scion xA
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
My sons chain won't stay on and it falls off when
Aug 09, 2011 | Cycling
How to cut a trap door on 2000 silverado to access fuel pum
The easiest way to access the fule pump is to lift the bed or drop the tank. I have lifted the bed on many occasions. Just remove the bolts that hold it to the frame, but leave the two at the rear real loose, That way when you lift the front of the bed it will stay on the truck. Once it is lifted high enough, you can easily access the pump from the top of the tank. Cutting a "trap door" in the bed is not recommended as the sparks from cutting might ignite the gas fumes. Unless you take the bed off of the truck totaly, I wouldn't even attempt it.
Jul 31, 2011 | 2000 Chevrolet Silverado 1500
Pen gartridge jam
Is it an ink cartridge jam
Please follow steps below : STEP: Disconnect and Reconnect the Printer Power Supply
Unplug the power cord from the wall socket. Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Raise and Lower the Scanner Assembly on the Printer
Lift the lid of the scanner until the locking bar catches to move the ink cartridge carrier to the center position.
Release the locking bar and close the scanner assembly.
If the ink cartridge carrier fails to center, repeat steps 1 and 2
Scanner Assembly Open but Without the Cartridge Carrier Centering
STEP: Check to See if the Ink Carrier Latches Are Open
Open the printer.
Check inside the printer to see if the cartridge carrier latches that hold the ink cartridges down have popped open.
Close the carrier latches
STEP: Remove any Torn or Stuck Pieces of Paper from the Input Tray and Output Tray
Disconnect the power brick from the back of the printer.
Lift the scanner unit.
Look down inside the printer and remove any torn or stuck paper from the input or output tray by pulling firmly.
Close the scanner unit.
Reconnect the power brick to the back of the printer
STEP: Clear Obstructions From the Input Tray
STEP: Fan the Paper
Grasp the **** of paper at one end (Figure 1).
Place your thumb on top of the opposite end of the paper and fan the paper like a deck of cards.
Flex the paper back and forth, and then fan it.
Straighten the edges of the stack on a level surface.
Top of Form 1
Bottom of Form 1
Additional Information
It is quite possible for objects such as pens, pencils, paperclips, and other small items to fall into the paper input tray causing paper jams to occur. Follow the below steps to try and clear any obstructions that may have fallen into the printer.
Caution:
The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
Remove all paper from the input tray.
Unplug the power brick from the back of the printer.
Unplug the USB cable from the back of the printer.
Lift the printer up and turn it upside down.
Caution:
Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
Jul 19, 2010 | HP OfficeJet t65 All-In-One InkJet Printer
Hayward Phantom pool cleaner-up/both/down switch replacement
There are 5 screws on the bottom, remove them and hold the cleaner together while turning it right side up. Lift off the top cover (watch the styrofoam inserts that go behind the back wheels), sometimes they fall out when the cover is removed but they're easy to put back in place. This will give you access to both the switch and the round gear box. Lift both out then put the switch on and lower the gear box back into place.
Mar 19, 2009 | Phantom Pool & Spa
Ink cartridge jam
ink cartridge jam
Wait 15 seconds.
Open the printer.
STEP: Fan the Paper
Grasp the ream of paper at one end (Figure 1).
Top of Form 1
Bottom of Form 1
Caution:
Caution:
Feb 02, 2008 | Dell 810 All-In-One InkJet Printer
"out of paper" error
new_caution.jpg Caution: The next steps involve lifting the printer and turning it upside down. Only perform these steps if you are willing and able to do so.
  1. Unplug the power brick from the back of the printer.
  2. Uplug the USB cable from the back of the printer.
  3. Lift the printer up and turn it upside down.
    new_caution.jpg Caution: Make sure that you are holding onto the scan bed to prevent it from falling open when the printer is turned upside down.
  4. Tilt the printer from side to side while it is upside down to see if any obstructions fall from the input tray.
Dec 31, 2007 | Dell 922 All-In-One InkJet Printer
Furniture Logo
488 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
