Question about CellPhoneTrek.com LG 840G Van Gogh Vase with Twelve Sunflowers Case
Says call divert set or call forwarding active
I think someone is having my calls forwarded to their phone
HOW DO I TRANSFER MY CALLS TO ANOTHER PHONE?
1. Find "Voice call"
2. Select divert type
3. Divert calls to alternative number
  • Key in the required number and tap Enable.
Aug 28, 2014 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Apr 25, 2012 | Panasonic KX-T7730 Corded Phone
Need instruction on how to call forward? Why charging to what is indicated as FREE?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
Activate
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
You will not be charged for activation or deactivation of this service. Only the call divert will be charged as a separate call.
Jul 23, 2011 | Cell Phones
Need instruction how to call forward?
Activate
Also:
  • enter ##002#
Samsung sch u350- how do you set up call forwarding
As your using samsung sch u350 you can forward your call by following simple step.Go to main menu select settings after that select call settings after that select call divert after that select divert all voice calls then activate you can give your another number there you can recive calls.Other wise you can forward it to voice mailbox.Your old number will recive only message .
Jun 14, 2011 | Samsung Smooth SCH-u350 Cell Phone
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
I have samsung champ and there it shows me conditional forwarding activated whike making a call how can i remove that pls help
This just means that people who call you while your making a call will be diverted to your voicemail.
This is standard practice. BUT Settings, Call settings, Call forwarding, and then there should be an option to disable all call forwarding options.
Dan
Jan 14, 2011 | Samsung SGH-D900 Cellular Phone
How do you forward your calls to another number?
its a network service if its not work call your service provider to activate this service,for forwarding you need to divert its to another number check divert option on your phone call settings
Nov 12, 2010 | Motorola Mobility Rival A455 Cell Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Want to divert calls from one Mitel Superset 4025 to another.
Under the Blue Superkey, there is an option for Call Forwarding.
Go to the call forwarding and put in the extension that you want to forward to, and then enable it.
To disable the call forwarding, you have to go back into the Blue Superkey and disable the call forwarding from there.
It's either that, or your system programmer may have given you a call forwarding button on the set to enable and disable easier.
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
CellPhoneTrek.com LG 840G Van Gogh Vase with Twelve Sunflowers Case Logo
73 people viewed this question
Top CellPhoneTrek.com Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CellPhoneTrek.com Toy Expert? Answer questions, earn points and help others
