Question about Dell 4100MP Multimedia Projector
Epson ep 835 overheating
Is there any place I can get an exploded view. Replaced. Bulb and filters not sure If fans are coming up to speed and I think there's a fan on bottom not sure if working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Try website "support.dell.com" for product assist/manuals.
Posted on Mar 22, 2014
Epson powerlite 200 overheating after 20 minutes of use then shuts off.
How's the filter, if it has one - cleaned out recently? Much dust in the airways? Tried setting it into "high altitude" (or simply "high fan speed") mode and seeing if that helps?
Jan 30, 2014 | Epson POWERLITE 74C Video Projector LCD,...
Bulb explodes on projector
There is a short or a grounding issue on this projector. It would have to be internal on this one for the bulb to get that much energy and not be able to release it any other way than to explode.
Oct 11, 2012 | Epson PowerLite 83 Plus Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
After it being on for 5-10 minutes, just shuts off manually. Already cleaned it out and replaced bulb. Now what?
It sounds like it is overheating. Check to make sure the cooling fan is coming on when you power it up. Please respond with your findings for further help in troubleshooting.
Apr 04, 2011 | Epson PowerLite 8200i Multimedia Projector
Is there an exploded view of the TV so I can see what I need to do to replace the bulb fan and also get a part number for it?
The service manual shows the lamp fan as - 8-835-859-11 MOTOR, DC SFF22A/C-NP; INTERNAL FAN ON TOP OF LAMPI do not have a copy of the manual but I was able to pull it up on line. It did not go very well with internet explorer (IE) so I used Google Chrome. The URL is "http://www.scribd.com/doc/16940552/Service-Manual-Kdsr60xbr1" This manual gives you all kinds of good information including what all of the blinking LEDs mean.
Mar 07, 2011 | Sony KDS-R50XBR1 50" HDTV
Epson 7550c projector - ELPLP07 lamp fuse.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 04, 2009 | Epson 5550c / 7550c Replacement Projector...
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
Overheating
There are contacts inside the Livingstation that make contact with the heat sensor on the bulb. If you take the bulb out you will see them in the upper right corner of the bulb housing in the TV. These can become corroded resulting in a poor connection between the TV and the bulb. A poor connection will make the TV think it's over heating even if it's not. There are 3 contacts in the TV and 3 on the bulb. Clean these contacts with a lint free cloth and some alcohol on both the TV and the bulb, being careful not to let your fingers touch the bulb. If your hands are too big to reach inside the TV, rub a pencil's eraser over the contacts to clean them. When putting the bulb back into the TV, seat as firmly as possible, then tighten the upper right screw first.
Jun 09, 2008 | Epson Livingstation LS57P2 57" Rear...
RCA HD61LPW42
How about the fan? I had a problem where the picture would not come on for a while and I noticed the fan speed fluctuating. There must be some saftey that keeps the bulb off if the fan isn't running. When I finally had to replace the bulb, the problem ceased.
Nov 09, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Dell 4100MP Multimedia Projector Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
