Question about Little Giant Plumbing
Ejector pump keeps running
I think the check valve is sticking
2 Suggested Answers
  • 63 Answers
SOURCE: water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Posted on Mar 24, 2009
Kenmore elite, can hear water running for ice maker constantly as of yesterday
Well if the water was constantly running into the icemaker, it would be consequently over filling and spilling out through the unit doors onto your floor. The icemaker can be making a whirling sound, which typically means the ejector arm is stuck, most likely due to a failed thermostat or heater in the ice maker itself. If the water valve is stuck and truly is spilling everwhere in your unit, the problem could be caused by a stuck module contact in the ice maker, or a defective water valve. I guess the best thing to do is to isolate the problem, define where exactly you are hearing the noise. Icemaker assembly, or water valve? If the water valve is sticking open, identify which side of the water valve solonoid is making noise, then check the incoming line voltage to the unit with a meter. If there is 110v approximately coming into the valve, replace the ice maker module. If there is no voltage coming into the unit but it remains on, turn off the water supply and replace the valve. Some high end refrigerators use a relay board to activate the water valve.. in this case you'll have to identify the correct relay for the water valve and make sure that its not sticking closed or malfunctioning, if this is truly your problem with the unit.
Dec 24, 2012 | Refrigerators
I have a one horse power pump and i want it to reach 50 lbs of pressure\r\nand it wont go over 40 lbs.
First off, have you checked the adjustment of the pressure switch? If not, please go to the answer at http://www.fixya.com/support/t6375131-pressure_switch which provides details.
If that doesn't solve the problem because the pump won't provide the pressure, it depends on many factors. Assuming you have the correct pump for your well and system, the pressure/flowrate will also depend on the nozzle and venturi installed in the ejector set down the well. The ejector set comes with a table which offers the chance to increase flow or pressure. Assuming you have the correct jet/venturi for your pump and well depth, there is a simple routine which should be followed at startup of the pump the first time. Close the control valve which is a plastic threaded rod sticking out above the pump fittings coming from the well. Screw it right in. Ensure the pump is primed and that all plugs and faucets etc are closed. Then run the pump and while it is running, unscrew the control valve until the pressure gauge needle flutters. Screw the control valve closed until the fluttering stop and then at least a quarter turn. This provides your optimum pressure/flow for the depth of well, the nozzle and venturi installed. If this still doesn't provide the pressure you require, you may need to swap out the ejector set nozzle and venturi and then re-adjust.
Aug 11, 2010 | Flotec 1 Hp Deep Well Pump
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
1984 RANGER IDLE PROMLEM...WONT IDLE CORRECTLY.
First check:
Your EGR valve is carbon up and is sticking open. You have to take it off and clean with carbon cleaner. (EGR controls idle)
Second check:
Could be fuel pump is starting to go on it.
May 17, 2009 | 1984 Ford Ranger
Ejector pumps started to go off frequently
The ejector pumps probably pump to the same sewer pipe you had rooted. Rooting can do damage. Trees can break into your sewer pipe, jam them up with roots, and let ground water in. The ground water may be following your sewer pipes on the outside back to your house. It costs a lot, but you can have your pipes examined with a tv camera, the rooter people can do that. Make sure your ejectors have check valves, and they are working right. It's easy for something to get stuck in the check, and then water will come back.
May 01, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Water backing up into my basement ejector pump during heavy rain
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
How to Install plumbing in the basement?
A sewer ejector pump is the answer. The waster line is run into the sump basin, pumped through a checkvalve into  the sewer line that grades with gravity.  A vent pipe needs to be run also, (you can't pump out without replacing the air, it's like trying to suck air out of a bottle) If you add a high water alarm, which is a good idea. It is run off of a separate electrical breaker (insurance) to let you know if the pump isn't working before it's flood time.  The check valve makes sure, that what you pump out, stays out. Otherwise the pump will keep cycling.
Aug 27, 2008 | West Brass WestBrass Faucet Master Large...
U-Line Model WCM48
You can try to advance your icemaker by removing the white cover on your icemaker and turn the smaller gear counterclockwise to advance the icemaker. When the icemaker starts wait until the ejector blade gets to 10 oclock position this is where it calls for water. The test would be unplug the coil on the valve and put a meter lead on each one. If you see 120 volts then replace the valve. If you dont see it it could be the water switch inside the head of icemaker.
Aug 05, 2008 | U-Line Refrigerator Ice Maker
Maytag washer trouble
If water is going into basket and just not filling up, make sure the end of the drain hose is terminated higher than the basket or the water will run out just as fast as it fills.
If no water coming in at all, the inlet/mixing valve may be bad.
Jun 26, 2008 | Maytag Washing Machines
Plumbing Logo
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
