Question about Canon EOS 550D Rebel T2i Digital Camera
Auto focus not working
Cannot auto focus
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 32 Answers
Have you checked the lens AF/MF button?
Perhaps your lens is in Manual Focus mode?
auto focus not working - auto-focus-not-working-mscpfsinexfgkvjnkzk5efuu-2-0.png
Posted on May 11, 2016
Won't focus properly on auto focus.
Depending on your lens, you may have an AF/MF switch. Make sure it's set to AF for Auto Focus. Try increasing your light levels. Does focus work in a good light setting?
You should have a button that looks like a matrix. Press this button to set your focus point. Use the joy-stick like wheel to select the focus point. Press it to select Auto Focus points.
Aug 27, 2013 | Canon EOS Rebel XSi Digital Camera
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
May 26, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
AUTO FOCUS NOT WORKING. SOMETIMES IF YOU REINSERT BATTERIES THE FEATURE WORKS AGAIN
Auto focus for an for digital cameras have a nasty habit of that, do what I do, and my Auto Focus works too, but I use Manuel focus all the time, and I shoot professional golf....I never auto focus nothing....my eye is faster and better than the lens.
Mar 22, 2010 | Nikon D60 Digital Camera
The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Sep 29, 2009 | Sony Alpha DSLR-A200K Digital Camera
Auto Focus not working
It depends on how long you have owned the camera, but I find it doubtful that it would be waring out. Sometimes after messing with the auto focus buttons my camera no longer focuses on its own, I then reset the settings and re-select auto focus. This always fixes my problem. I hope you find a solution. God bless...
Aug 16, 2009 | Cameras
Camara problem
Auto focus is supported with AF-S and AF-1 lenses only.
A mode switch is on the lens ,it should be in A position to activate auto focus.
In the menu select auto focus
Mar 24, 2008 | Nikon D40x Digital Camera
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Canon EOS 550D Rebel T2i Digital Camera Logo
158 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
