Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
What are the factory settings for the "Hi" & "Lo" Carb Jets for the Husqvarna 125L (Weed Trimmer). 1 turn out, 1/2 turn out, etc. Can't get to idle at all, have idle screw all the way in and does nothing, can only keep running if revved up
  • 284 Answers
Find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
Posted on Jun 14, 2009
How to replace primer bulb on husqvarna 125 l weed eater
It just unscrews off the side of the carb, 4 screws hold it on. Its a pretty simple procedure.
Apr 25, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
How do I stop the shaft rotation on my model 125L weed trimmer?
If its 'running on' then you either have your idle set up too high or stretch clutch springs.
Jul 13, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
In what order does a carburetor gasket kit go on a husqvarna 125L weed trimmer
There is only one gasket, Jenny. To figure ouut which way it goes, first put it onto the carby, then transfer it to the motor. Next put on the carby, and tighten the screws. Then hook up the electrical wiring and the fuel lines, and the job's done.
Jun 16, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
My husqvarna 125L weed eater will only run with the choke on why ?
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
May 08, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
How to set the jets on a 125 weed trimmer. The revs are too high and adjusting the idle screw makes no difference.
The idle screw is just that, for idle. The second screw is for high speed. I'm not real familiar with this motor. Try turning the second screw in or out slowly but not to far, you'll want to make sure you still maintain good throttle response. Hope this helps
Apr 26, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
What is the oil to gas ratio for the husqvarna 125l weed eater
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Stalls out, does not want to take gas
THATS WHAT IT NEEDS YOUHAVE TO TAKE IT TO A SHOP FOR THAT
Aug 08, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
1,521 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
