Question about Gateway M275 Tablet PC
How can i update bios
Slow down
Why is nextbook running slow closing apps. General misbehavior
Delete cookies and run a virus scan. There's more but start there. Make sure all your open files are closed. Is your storage almost full? That will slow it down. How many devices are running off your router? Make sure you stay within its capacity. Run a speed check make sure it's the parameters your paying for. Make sure your updates are up to date.
Sep 28, 2017 | Nextbook Tablets & eReaders
I bought it about two days ago it been running very slow an over half my apps not responding if not freezeing an not openning
I updated my tablet, but now it's running slowly - Telegraph
www.telegraph.co.uk > ... > Technology Advice
The Daily TelegraphJan 17, 2015 - Since then the tablet has been very slow. It often freezes and sometimes will not access some websites. Is there going to be another update or ...
My Android is slow: 5 things you can do to speed your ...
www.androidcentral.com/my-android-slow-5-things-you...
Android CentralOct 2, 2014 - Make your Android fast again - it *is* possible We've all been there. ...but the biggest reason I choose my S3 over S5 is memory! no 32GB or more option!..... Those apps are NOT running anyway after boot up (they're not set to ..... Some games may animate so fast you'll have to slow them down a little.
My Android tablet is getting slower and slower - Forums - CNET
www.cnet.com > Forums > Android
CNET
Jan 06, 2016 | Tablets & eReaders
When I installed the update in January it made my tablet go so slow and took forever to turn on. Will the new update fix this?
It should be OK mine was. U mention its going slow ..if u have the full main app of Facebook uninstall it u can open Facebook in you're browser just write Facebook login in browser...I have 2 nexus 7 and the full Facebook app makes them go slow & lock up hope this helps. ...,.
Apr 16, 2015 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My screen flicks alot or sometimes the desktop goes black and then reappear
Hi! try this steps. First reinstall your video card driver. Uninstall the first one then install back the driver. Second update your computer BIOS driver . (BIOS driver can be found on the website of HP as well) But make sure that if you update the Bios your battery charge should be above 30% or more than that and should be plug in the Ac adapter. Because if there will be power failure while updating it, motherboard will be defective .... Just to make sure call HP hotline for further assistance. Hope this will help you . God Bless.
Apr 24, 2011 | HP Pavilion tx2500z 121" HighDefinition HP...
How do you update the serial number in the BIOS
This is *NOT* a question about an ACER Travelmate LCD display.
The "short" answer is "you cannot", without the proper tools,
namely the tools to physically remove the BIOS chip from the motherboard, and a 'PROM-burner' device, to extract the contents
of the BIOS (about 2Mbits of data), update a few bits, and then
to "program" the updated data back onto the PROM (Programmablel Read Only Memory) chip, and then reinstall the BIOS chip back into your motherboard.
Good luck! Always "experiment" with a "test" motherboard, rather than first goofing-up your "production" motherboard.
Jan 09, 2010 | Acer TravelMate C300 14.1 XGA LCD Display...
I have a HP/Compaq TC4400 tablet pc. I recently had to replace the motherboard and now have a problem with booting. I get the following message: The following configuration change was requested to this...
there are two way either you set the password in system bios or reformat the hard drive and reinstall the operating system . it will fix all the seeting to new motherboard.
Nov 21, 2009 | Compaq tc4400 Tablet PC
Upgraded mem.now mon pc dont shut off fan con to run
Computer doesn’t power down when users shut down
In some cases, Windows XP’s Setup program can misidentify the power management scheme in a computer’s BIOS as Advanced Power Management (APM) instead of Advanced Configuration Power Interface (ACPI). When this happens, users will notice that the computer no longer automatically powers down when they shut down Windows XP. Instead, they’ll see the message It Is Now Safe To Turn Off Your Computer and be forced to manually press the power button to turn off the computer.
You can verify this problem by checking the power management configuration in two places—Device Manager and the Control Panel. To quickly access Device Manager, select Start | Run, type Devmgmt.msc in the Open text box, and click OK. When you see the Device Manager window, locate and open the System Devices item. If Setup identified the system as having an APM-compliant BIOS, it will be listed as a Standard PC in the System Devices tree. (If it were identified as having an ACPI-compliant BIOS, you would see it listed here as a Microsoft ACPI-Compliant System.)
To check the power management configuration in the Control Panel, open the Control Panel from the Start menu. If the system is using Category View, select Performance And Maintenance and then click the Power Options icon. If the system is using Classic View, just click the Power Options icon. If Setup identified the system as having an APM-compliant BIOS, you’ll see an APM tab in the Power Options Properties dialog box. (If the system were identified as having an ACPI-compliant BIOS, you wouldn’t see an APM tab.)
You may be able to fix this problem with a BIOS update. To begin, check with the computer manufacturer’s Web site to see if it’s providing the latest BIOS update. If you’re troubleshooting an off-brand computer, you may be on your own as far as tracking down the BIOS update. Here’s how.
Once you obtain and install the BIOS update according to the manufacturer’s instructions, you must perform what I call a Refresh Installation, in which you reinstall Windows XP on top of an existing Windows XP installation. You must perform this reinstall operation because the power management features are tied to a special power management Hardware Abstraction Layer (HAL). During the Refresh Installation procedure, Setup will completely redetect all installed hardware, including the updated BIOS, and rebuild the power management HAL as well as the part of the registry in which information about the installed hardware is stored.
Jul 20, 2009 | Gateway M280E
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Gateway M275 Tablet PC Logo
18 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
