Question about Hardware & Accessories
Sansai digital time
How to program
Bush DFTA46R set top box missing receiver. Have universal remote, wondering if this sansai universal remote will work, anyone have codes?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Sep 22, 2016 | Universal Televison & Video
Have sansai universal remote and need code for 60inch Dse tv, cheers mate
that sansai universal remote not supported online
use contact us menu
email or ring head office
http://sansai.com.au/index.php?#.V8vlSq1CZdg
Sep 04, 2016 | Universal Televison & Video
HOW DO I SET UP SANSAI URC-501A UNIVERSAL REMOTE FOR SAMSUNG TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jul 10, 2016 | Samsung Televison & Video
How do I use learning function SANSAI URC L969 ? l do not have maual
How to use learn function on sansai URC L969 universal ...
www.fixya.com/support/t25610267-use_learn_function_sansai_urc_l969
Mar 27, 2015 - Posted on Mar 27, 2015.
Hi, I just bought the Sansai URC-L969 8 in 1 universal - Fixya
www.fixya.com/support/t9376242-just_bought_sansai
Jun 3, 2011 - Hi, I just bought the Sansai URC-L969 8 in 1 universal remote, ... the manual) i have put in all the codes and it just doesnt seem to work. ... Turn your device back on and try all the remote's functions to ensure they are working
Jan 27, 2016 | Televison & Video
Is there a four digit code for the Sansai URC-501A universal remote to operate the Wintal PVR10HD?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Search the site by brand name to your TV.
Sep 06, 2014 | Televison & Video
Sansai urc l969 codes list lost
I was struggling to get Sansai URC-L969 working also. After a looking through a ton of sites like this one, I found a similar model of Sansai Universal remote user manual here:
URC 969 Instruction Download Sansai
It lists all the IR codes as well as how to use the damn remote. I could get none of the codes to work (which might be down to the fact that there is no "0" key, A key that is used in EVERY code).
I got mine working using the Manually Search Code instructions on page 2 of these instructions. Another hurdle was the "TV1" button seems not to be programmable for me - It would not "twinkle" as the instructions says it should. The other preset buttons (VCR, CBL, DVD, TV2, TV3, SAT, AUX) were programmable.
In case the link gets moved or anything, here is a quick run through the instructions:
1. Hold "Set" then press the button you wish to program - I used "TV2"
2. The Set button stays lit, press it again so it's flashing
3. Turn on television and point remote at it and press the Power button slowly until the television turns off.
4. Your remote now has the right code selected, press the "TV2" button once more to save the configuration to the button.
5. If the other buttons don't work as expected (volume etc), repeat the process of cycling through all the configurations again and just ignore the first one that turns off the television.
Hope that saves someone the headache I have had the past two days while looking for information on this brand of remote. No one seems to know what they're talking about when they answer these questions.
GOOD LUCK.
-L
Mar 02, 2014 | Televison & Video
Cant put videos
if you put some videos to your sansai try to convert first "3gp file" Or mp4 file because there's is specific file to put videos to you sansai
May 22, 2009 | SanDisk Sansa e200 MP3 Player
Hardware & Accessories Logo
21 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
