Zanussi zwd14791w doasnt change programs
    New Friend:
My washer dryer is stuck on child lock and super quick mode how can I get this off please?
Posted on Sep 04, 2016
End of program?
check with Zanussi website tech support .
Dec 02, 2017 | Zanussi Washing Machines
Power is on, light is on,program stuck on 70'c setting. Toggle switch when pressed does not change program as it would normally.
i, just read yuor question, i have same problem with same model but atuck at 60. Did you resolve this?
Jul 06, 2011 | Zanussi 23 in. ZDi6053SX Built-in...
How much does a new PCB board cost for a Zanussi Jetstream 1600? Is it cost effective to change it?
hi if the product number is914512801 followed by 00 the electronic is £170 and has to be programmed on the machine (not do it yourself repair) . if the product number is followed by 01 the electronic is £82 and does not need programming as it is pre configured This you can do. I would look for earth faults on the heater or motor or short circuit on the pump or solonoid valves before changing the electronic . hope this helps.
Jan 20, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
Car revs but doasnt start
You say you have spark for sure ? If so, remove air inlet hose at throttle body, then try spraying a little WD-40 in throttle body, with plate open, then try to start. If it kicks over & fires up for a second or two, you have a fuel delivery problem. Lets start there & see what you get.
Jan 02, 2009 | 1998 Plymouth Neon
Doasnt charge
Often this happens because the AC soket in the laptop has a broken contact.
In this case the tehnician access the motherboard and resolder the on board contacts.
This is not a job for beginner, requires taking apart teh laptop completely, taking out the motherboard, and doing a precision soldering on the motherboard.
Ask a quote for the repair at a local repair shop, or call Dell and ask the cost of a Warranty extension that will cover factory repair, usually is cheaper than the repair job.
Nov 08, 2008 | Dell Inspiron 6000 Notebook
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
