Question about Mr. Coffee FTX29 12-Cup Coffee Maker
Does not turn on
Poer outrage coffee maker wont start after that
My Mr Coffee model #CJX21CP 12 cup started by being hard to turn on and now wont turn on at all but the clock is working any ideas?
I don't have a solution, I have a question. Both of the high Temp.
tubing's are cracked and leak and need to be replaced, where do I get 2 new ones for Model CJX21CP Mr. coffee does not offer any of these parts. Help!!!!
Aug 06, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Wont start brewing and display wont turn off just says brewing
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
When i turn it on it says not ready. you hear the pump come on and the water starts comeing out. it wont stop until you turn it off
heatman101
Sep 05, 2011 | Keurig B70 Coffee Maker
My keurig b50 when turned on wont start or pump water to start
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 20, 2011 | Keurig B50 Coffee Maker
I just plugged the coffee maker back its not making coffee!
So folks to solve this problem I used the last resort....don't laugh, but I actually started to hit the machine very hard on the top and from the side and all of sudden it started to work. When in doubt hit it!
Oct 18, 2009 | Keurig Special Edition B60 Coffee Maker
I can't turn off the grinder- sometimes it just starts up in the middle of the brew cycle- sometimes it wont even start- i have only had this machine GRIND& BREW coffee maker about 6 mo- is this...
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Oct 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore coffee maker wont brew model #81006
This coffee pot was recalled,I just took mine back to sears essentials last night and they replaced it with the new improved one,they just got them in.Good day,Sandi
Jul 23, 2008 | Kenmore KBC12 Coffee Maker
Car wont start
Generally you will need to contact a dealership and give them your VIN number and they will have a new key made specifically for that car.
Oct 24, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Mr. Coffee FTX29 12-Cup Coffee Maker Logo
15 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
