Question about Acer Aspire 5253-bz692
Battery not charging
Is there a bios update to fix problem
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Dell E1705 will not charge aftermarket battery. Is there any work around. AC adapter is ok.
Hi there!
Try to check a few things first.
Go to the BIOS set up, which you can access by pressing f2 when you start up the computer,
Then go to the option that says battery info,
Check if the ac adapter is detected,
And check if the battery is detected,
If any of this things is not detected
Then try this things,
If in the ac adapter it says unknown,
boot to your windows normally
then make sure you still have at least
12% on the battery charge.
Then download the latest flash BIOS
update your BIOS then after you update it,
it should fix your not charging issue and fix the unknown ac adapter if ever that's the case,
But after you do that and the same thing happens,
You'll need to replace the motherboard of that computer.
Hope this helps!
Apr 13, 2010 | Dell Inspiron E1705 Notebook
Not charging the battery
If the laptop is not charging the battery, I would suggest to download and install the BIOS update at www.support.dell.com (if you have at least 20% battery charge) If this fix wont resolve the issue, i apologize but the motherboard needs to be replaced. Hope this helps
Dec 15, 2009 | Dell Latitude D600 Notebook
My dell inspiron battery won't charge. The battery is new and the charger works fine.....when I go to the battery it shows it is discharging when charger not plugged in and it shows I'm running on the a/c...
sounds like a motherboard problem. to isolate it, check the BIOS and look for the battery info and health to see if the battery is recognized by the system. if available, try a spare battery. Updating the BIOS can also help. There are BIOS updates that contain fixes which can help improve battery performance. if all else fails, the motherboard will have to be replaced. Check with Dell support if your laptop is still in warranty.
Oct 16, 2009 | Dell Latitude D600 Notebook
I have an LG laptop model LS55 Express..Of late, my battery isn't getting charged, though I bought new a battery..No Idea why? Any quick fix please !!
Check your power adapter at the laptop make sure it isn't loose. If it isn't loose, check for a BIOS update from LG's website. Check the readme.txt file or on the website for what the BIOS update fixes to make sure that the update will fix it. I would give LG tech support a call to double check. If the BIOS update doesn't work then you have a hardware issue - the motherboard charging components maybe fried.
Sep 13, 2009 | Computers & Internet
Battery won't charge right
CHECK WITH ASUS FOR A NEW BIOS UPDATE. I HAD PROBLEMS WITH BATTERY CHARGING AND THE BIOS UPDATE FIXED IT.
Jan 11, 2009 | Acer Aspire 7720-4428 Notebook PC
Battery not charging. i have changed the battery and charger,stil
Run A BIOS UPdate For Your Make/ Model...
Your Laptop Doesnt want to recognise it because it is not an OEM part... BIOS Update should have a fix in it for that.
Nov 17, 2008 | Dell Latitude D505 Notebook
Bios update failed, computer will not start
the bios of your motherboard has gone , replace it,
Oct 25, 2008 | Toshiba Satellite M115-S3094 Notebook
Battery not found in power management screen charge light goes out
The Charging circuit on the motherboard is bad, and the motherboard will need to be replaced.
Sorry
May 18, 2008 | Computers & Internet
Acer Aspire 5253-bz692 Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
