Question about Kenmore Dryers
I can't find the thermal fuse on my dryer it won't run at all
I have replaced the door part to see if my dryer would work does not won't turn on at all maybe its the thermal fuse but I can't find it
My thermal fuse was located on the back of the dryer. I think it was in the exhaust air stream if I remember correctly. Check it with a continuity tester to see if it is bad before replacement.
Posted on Jun 14, 2009
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
Maytag dryer won't turn on and start cycle
Hi Calvin D Robinson Jr.
Here are a few things to check
**************************************************************************ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Oct 07, 2012 | Maytag SDE4606A Electric Dryer
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Dryer wont start
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details. Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Amana Dryers
Maytag Neptune dryer was always drying on high heat, now won't turn on
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 27, 2012 | Maytag Dryers
My roper dryer won't start unless i find just the
Hi jodiew0228...
Sounds like you have two problems
1...Bad timer...replace your timer
2...Something wrong in the heating circuit...
Here are a few things to check:
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
Please take time to rate me thumbs up
Sep 16, 2011 | Roper Dryers
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
