Question about Casio Office Equipment & Supplies
Casio jj 120 how to change the battery
Don't know how to change the battery
My Xanadu clock is not working and I don't know
Change the battery. I might be flat. Clean the terminals before putting the new battery in because the old one might have leaked.
Aug 02, 2013 | Cars & Trucks
After changing the battery the sound system is locked and I don't know the code number to unlock
so desconect the battery and reset the code.look up the stereo on the internet and find out how too reset it.Have too know mosel # and make.
Mar 28, 2013 | 1998 Saturn SL
Changed o2 sensor engine light went off but came back on
I don't know if you have reset the computer but if not take one battery terminal off for about 5 minutes and that will reset your computer. If you don't have anymore problems it should not come back on.
Aug 20, 2012 | 2000 Ford Windstar
Changing battery on TE4027 watch
Pl don't try yourself better visit a well experienced watch maker to replace it otherwise you will finish with worse
Jun 23, 2012 | Ted Baker TE4027 Watch
Were does it go? Also battery died can i just jump it or do i need to charge it?
Where does what go?
You need to know how old the battery is,first
Then you need to test the battery, before you
attempt to jump or charge it
I don't know why you expect someone on the
internet to know all about the battery history
& then tell you to change it.
If you said it went 8 years,then that would be
a good reason to install a new one.
May 29, 2012 | 2000 Nissan Pathfinder
How to change cells in cordless batteries
It's very difficult to replace the cells and get everything soldered correctly. The best solution if you don't want to buy new batteries, is to take them to a place like batteries plus or a similar place and have them change the cells out.
Apr 24, 2012 | Bosch 13624 24V Cordless Hammer Drills
I am trying to change my CMOS battery in myAcer Extensa 4420. I am unable to locate it partly because I don't know where to look and because I don't know what it may look like. I think it is a...
you'll find a lot of laptops have inaccessible bios batteries. Yes the cmos battery does look like a nickel sized one. I think the battery is located under the largest cover plate on the base of the laptop in this case, so it may not be too difficult getting to it.
A word of caution, this laptop came with a power on password, which will want inputting if you change the battery ( called a bios pass), if you do not have this, you might find you are locked out of the laptop OS)
Jul 18, 2011 | Acer EXTENSA 44205874 COMPATIBLE LAPTOP...
hah im sorry to say this but it is a case of poor design to find the battery you must strip the computer down a bit the battery is located under the keyboard and palm rest on the mother board. the battery is flat and is in a round socket it shouldn't be hard to spot it once your there, here's an image of what it should look like http://blackman.amicofigo.com/gallery/index.php/Arduino/i2c-Items/rtc-battery .
Jul 18, 2011 | Acer CHARGER for Acer Extensa 4220, 4420,...
I don't have a manual. My scales have been very variable, like this morning showing that I had gained nearly 5 lbs in one day. I've been sick and am not eating much, so I know that can't be...
I don't have a manual. The readout is in kilos rather than pounds some of the time. How can I get it to read in pounds all the time? Also I replaced the batteries. Are they supose to be both with + up? I have a replacement heart valve so I don't want to know body fat. How do I make sure it is off?
Jun 23, 2011 | Taylor & Digital Scale Lithium Scale
My SX 100 camera says change batteries
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Sep 02, 2009 | Canon PowerShot SX100 IS Digital Camera
51 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
