Question about Breville 2200w Steam Iron Pink & White S/s Soleplate
Stuck steam button
Steam button stuck in
How to release the stuck steam button stuck in the up position in a morphy richard
On this model i believe you have to slide the button back to release perminent steam function. I am not sure what screws are on this iron as to what they are called.
regards, I hope this was useful.
May 13, 2014 | Irons
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Steam button stuck
put some vinegar in your iron and swash it around. It will remove the calcium or lime that is making your button stuck. Be sure to run a lot of water through the iron after or your clothes will stink.
Apr 24, 2013 | Black & Decker Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
Steam Button Sticks in
vinegar the iron its calcified,it will clean out
Sep 30, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Breville 2200w Steam Iron Pink & White S/s Soleplate Logo
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
