Question about Kitchen Appliances - Others
Manual for a VTA warping machine
1995 model
I have a 1995 jeep grand cherokee limited with 4.0l motor that won't start, please see my details below.
is this a USA jeep or export? (immo differences)
we do not know what turn over means.
in this case you meant engine cranks fast and will not start.
Changing out the CKP was a bad idle.
1 of 4 , engine, 4L (veries but unstated trans)
must be calibrated or its wrecked at the first turn of CRAnking
So be ready for 2 causes of dead spark is that fun ,no.
this is what you did wrong, if compression is ok.
1: check all fuse first. we test all ones that look ok. see?
2: then we scan it cranking, or all this is hopeless, see why?
it will tell you why there is no spark, but you skipped step 2.
3: not only that but you didnt check the ASD relay.
if its not pulling in the PCM is telling you why.
if its pulling in and dropping out, then pcm tells you why.
if ASD holds in full time cranking PCM is happy in this regard.
there 6 to 8 reason for ASD to drop. one is immoblizer upset.
I will stop here, as spark needs to be corrected.
here is the no start page. spark dead help, knowing that.
sparks dead so no need to read the no start page,
we go right to ASD tests
see the 8 ways? (yours will be less than 8, for 1993)
http://jeepdied.com/ASD.html
this is the only tool i know that scans 93/95s
https://www.amazon.com/INNOVA-3120-Diagnostic-Reader-Vehicles/dp/B000KID2ZC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1395411804&sr=1-1&keywords=INNOVA+3120
nowt the alarm VTA deal.
The ZJ 1993-1995 VTA does not cut the engine via ASD (IMMO) in the USA, but in Europe it does (if opted there)
see its really the world wide web, and ive no clue where you are or what engine you have.
nor options like VTA (T is for theft)
Oct 01, 2016 | 1995 Jeep Grand Cherokee
PERMANENTLY DISABLING ANTI THEFT ON 1995 JEEP CHEROKEE
see this link
what makes you think its (anti theft)??
all jeeps made with Immobilizer, (VTSS/VTA its called then)
the cluster has lamp that tells you VTSS has imobilized the engine (cuts fuel)
if the immo lamp is on, then see below.
93 was first year, click hack 93-98
if not glowing that immo lamp
that means its just a no start.
cranks but will not start has over 50 causes.
covered on same page but is called no start.
ZJ 1995
this is the VTA page 8q in the fsm
The Vehicle Theft Alarm (VTA) system is an available
option on Grand Cherokee models. This system
is designed to protect against vehicle theft by monitoring
vehicle doors, hood, liftgate and ignition action
for unauthorized operation. When unauthorized operation
is detected, the VTA system responds by sounding
the horn, flashing the headlamps, park and tail
lamps and providing an engine no-run feature. Following
are general descriptions of the features of the
VTA system. Refer to Group 8W - Wiring Diagrams
for complete circuit descriptions and diagrams
see that lamp below, this tells you what's up.
26166726-iznfychya1k5sjkhauts20c0-4-0.jpg the lamp glows key on to tell you Im alive and that im ok booting up. but then goes out to start car.
does it?
Apr 17, 2016 | 1995 Jeep Grand Cherokee
HOW DO I PERMANENTLY DISABLE ANTI THEFT SYSTEM ON MY 1995 JEEP CHEROKEE
see this link
ZJ 1995
does it?
Where can I find a manual for a zte model n9518
The ZTE N9518 is the ZTE Warp Elite. The manual is on the ZTE product page: https://www.zteusa.com/zte-warp-elite#support . Make sure to go to the Support section and then click on Manuals. The direct link to the manual is https://d1exow25948tx9.cloudfront.net/media/wysiwyg/warp-elite/ZTE_Warp_Elite_User_Guide_English_-_PDF_-_7.55MB_.pdf .
I hope this helps.
Jan 04, 2016 | ZTE Cell Phones
Vibration in the brake pedal
This problem is caused by the front disk brake rotors being warped, they must be removed and machined flat again on a brake rotor lathe or replaced depending on how bad the problem is.
Nov 15, 2010 | 1995 Toyota Camry
I had a blowen headgasket im fix it my self i tryed to take spark plugs out to find out the heat kinda melted spark plug coils and they wont come out? 1995 toyota camery 4cly
If ur having some probs in taking out that warped spark plug. Bring the head to the machine shop and let them do the job and also have ur head GRIND to have an EQUAL flat surface on thehead! Am sure its already WARPED! Hope that makes ur job more easily! Taah!
Nov 11, 2010 | 1996 Toyota Camry
Want to disconnect security system
Impossible to disconnect the vta in this Jeep, its all part of the PCM, BCM, programing from factury, just get it fixed, the door key cly switches are common problem with these Jeeps, has the harness going to them. some times the connecters fall off, or wires break in the door jamb. GOOD LUCK, RDJRP
Aug 16, 2009 | 1995 Jeep Grand Cherokee
Antitheft on my 1999 dodge intrepid
Not unless you are a CHrysler tech with access to scan tools, DBRIII, is the one to use, its all part of the screem module, (skim and vta), you can not dissable on certain models, LH is one of them....if there is a problem with the vta, take it in to a dealer. GOOD LUCK RDJRP
Jul 27, 2009 | 1999 Dodge Intrepid
Kitchen Appliances - Others Logo
26 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
