118.01kg to lbs converter chart
What is the answer to 118.01kg = to in lbs
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
118.01 kg is about 260.17 lb.
Posted on Apr 15, 2014
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
What is ideal weight for male 5ft61/2height to weight chart
The ideal weight can vary by doctors opinion, but the range is very small. Body bone structure also makes a big difference, hence no one can or should answer your question without knowing your built.
The range from the very low to the very high is 104 lbs to 137 lbs.
The 104 would be for a small frame, and the 137 being a large frame.
With a medium frame in-between.
May 10, 2014 | Health & Beauty
Charging scale will not go to lb.
charging scale for an evaporative wtf?? Look up a conversion chart and convert lbs to kgs or go buy a new scale...
Jun 15, 2011 | Mastercool 67471 Evaporative Cooler Air...
Convert 168 in-lbs into Ft-lbs
Divide by 12 to get the answer.
Dec 24, 2010 | 2000 Chevrolet Impala
Lincoln 2007 town car po430 repeating
Left Exhaust Converter
Now you need to find out why
Is the converter bad?
Is the O2 Sensor Bad
There is a long list to go through, to get
that answer.
You need to follow the factory diagnostic
trouble charts to resolve.
Nothing gets replaced, until you know all
the answers,what happened and why
Nov 20, 2010 | 2004 Lincoln LS
NEED FORD 2.2l head gaskets torque chart
Tighten the head bolts 29 to 32 ft lbs , then tighten again to 59 to 64 ft lbs
Apr 17, 2010 | 1989 Ford Probe
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
I need the torque spec for camshafts / 98 Dodge Neon 2.0 dohc
Here is the factory torque chart for all fasteners on the 2.0L
TORQUE CHART 2.0L DOHC DESCRIPTION TORQUE Camshaft Sensor Pick-Up Bolts 9.6 N·m (85 in. lbs.) Camshaft Sprocket Bolt 115 N·m (85 ft. lbs.) Connecting Rod Cap Bolts 27 N·m (20 ft. lbs.) Plus 1/4 Turn Collar - Oil Pan to Transaxle Step 1: Collar to Oil Pan Bolts 3 N·m (30 in. lbs.) Step 2: Collar to Transaxle Bolts 108 N·m (80 ft. lbs.) Step 3: Collar to Oil Pan Bolts 54 N·m (40 ft. lbs.) Crankshaft Main Bearing Cap/Bedplate M8 Bedplate Bolts 30 N·m (22 ft. lbs.) M11 Main Cap Bolts 81 N·m (60 ft. lbs.) Crankshaft Damper Bolt 142 N·m (105 ft. lbs.) Cylinder Head Bolts Refer To Cylinder Head Installation Cylinder Head Cover Bolts 12 N·m (105 in. lbs.) Drive Plate to Crankshaft Bolts 95 N·m (70 ft. lbs.) Engine Mount Bracket Bolts 61 N·m (45 ft. lbs.) Exhaust Manifold to Cylinder Head Bolts 23 N·m (200 in. lbs.) Exhaust Manifold Heat Shield Bolts 15 N·m (130 in. lbs.) Intake Manifold Bolts 28 N·m (250 in. lbs.) Oil Filter Adapter Fastener 80 N·m (60 ft. lbs.) Oil Filter 20 N·m (15 ft. lbs.) Oil Pan Bolts 12 N·m (105 in. lbs.) Drain Plug 34 N·m (25 ft. lbs.) Oil Pump Attaching Bolts 28 N·m (250 in. lbs.) Oil Pump Cover Fastener 12 N·m (105 in. lbs.) Oil Pump Pick-up Tube Bolt 28 N·m (250 in. lbs.) Oil Pump Relief Valve Cap 55 N·m (40 ft. lbs.) Spark Plugs Plug 28 N·m (20 ft. lbs.) Thermostat Housing Bolts 23 N·m (200 in lbs.) Timing Belt Tensioner Assembly - Mechanical Bolts 28 N·m (250 in. lbs.) Timing Belt Tensioner Assembly - Hydraulic Bolts 31 N·m (275 in. lbs.) Timing Belt T
Apr 28, 2009 | 1998 Dodge Neon
107 people viewed this question
k24674
