Setting swanview pro on android
Trying to set the remote view via swann view pro on android phone
merbuquis358
  • 94 Answers
SOURCE: I'm trying to copy some pictures from my Windows
Maybe the memory of your phone are not enough to copy more than 3 pictures.. That why it comes to hang because its not enough memory. Just see where are the pictures can save either in the phone memory or in the SD card.. If it is in the phone memory your just transfer it into the memory card..
Posted on Oct 21, 2009
SOURCE: not able to use remote viewing via no-ip
I had the same exact issue. I was using dyndns to connect, but i found out that when you login in the host, dont put your local ip address of the dvr, but instead put the internet ip address of your network. so instead of 192.168.0.5 for your local put the 89.137.24.124 for the internet address. That fixed my issue. Hope that works for you. Just make sure your username and password is right and the port is set up correct in your router to forward to the local ip of the dvr.
Posted on Mar 27, 2010
  • 102 Answers
SOURCE: the facebook and google applications
Im not sure but I think there's a compatibility issue. Try removing the appz and download them from the android market..
Posted on Apr 27, 2011
gazzzz42
  • 63 Answers
SOURCE: settings.apk force close
restoe fatory settings and unlock again
Posted on Nov 01, 2012
deepanshuvar
  • 61 Answers
SOURCE: I have an Android phone I accidentally uninstalled
clear the cache on the app and try again
Posted on Jun 26, 2014
Do I need internet connection to set up new swann security system even if I don't want to remotely view footage
go to the main menu in DVR find network setup and give it static IP
Example :
IP: 192.168.1.100
Gateway : 192.168.1.1
subnet: 255.255.255.0
then go to your monitor device (computer or smart phone)
inter the IP address (192.168.1.100)
into your browser address bar
Oct 20, 2016 | SWANN Home Security
I cant get any images on my devices. i can see it on the tv but not any of our phones
Swann has an excellent piece of software on CD, or available for download, complementary!. You can contact them, and their very helpful staff will assist you, and walk you through it. Or with your permission, they can take control of your computer, and do it all for you, and set up very easily, remote viewing from your phones.
Swann Communications Portal
Mar 10, 2015 | SWANN Home Security
Security setup
Yes most security DVR's have applications for remote viewing from IPhone/Android/Windows phone platforms.
Jul 29, 2014 | SWANN Home Security
How to monitor my surveillance system away from home
  1. Contact Swann, they have a very helpful support team.
  2. They have software that makes remote viewing so easy.
  3. Have your serial number for your DVR available, provide it to them and they will walk you through downloading the software and assisting you with the set up. It doesn't matter when you purchased it, they are very helpful.
  4. And if you would like, with your permission, they will take control of your computer and do it for you!
  5. Absolutely helpful team.
  1. Swann Communications Portal
Jun 14, 2014 | SWANN Home Security
We can only access the camera via wifi. Not able to use or view via cellular connections. Contacted Swann support 3x, they cannot figure it out. Any assistance is greatly appreciated!
I assume you have a App on your phone? To use a Cellular connection you must add :80 (which means Port 80), to the end of the Server Name. Check your Tablet or Phone that is connecting via WiFi for the Server Name and enter it into the phone. You may need to use a DDNS Domain usually when accessing remotely such as a computer over the internet.
Nov 15, 2017 | SWANN ADS-440 SwannEye Indoor/Outdoor...
I keep trying to link to my swanndvr pro series via my android devives and keeps. Saying server unavailabe. I had it working before but now has stopped
1) delete the operating prog. from mobile and reinstall and then try to run
2) if it is running on Dynamic IP then check your mobile port is forwarded in Router or Not
3) make new Id on Dyndns then operate
Oct 20, 2013 | Swann Communications 4Channel Security DVR...
No colour on my swann pro-530 cctv camera
Your cameras might be in PAL mode, go into system settings and change to NTSC setting.
May 03, 2013 | SWANN PRO-530 Multi-Purpose Day/Night...
Hi! I have a DVR4 2600 Swann, my cameras are working, but I can't get into the menu either directly on the DVR controls or via the remote???? I...
depress and hold the rewind button (<<) on the remote (or on the panel)until the units beeps.
It may take 20-30 seconds. or you may have to do it severalk times before you hear the beep. Once the unit beeps you should be able to get to the menu using the remote or the faceplate button.
Please note that the remote is infrared so the sensor on the faceplate is sensitive to where the remote is relative to the sensor on the faceplate.
Jun 01, 2012 | Swann Communications DVR4-2600 4 Channel...
Swann surveillance system at home
Try and take down the firewall. Then try remote access.
If that does not work . check the port forwarding settings on your router .
Dec 20, 2008 | Swann Communications DVR4-Pro-Net...
79 people viewed this question
 Grubhead
Grubhead
