Question about Ski-Doo Expedition SE 1200 4-TEC Winter Sports
Ski-doo wont start says trottle open
Ski-doo wont start says throttle open
SOURCE: when i go to start the ski doo it doesn't want to
first of all check your fuel filter and then the fuel line,it can be the fuel line inside the tank (if it do it only when in low gas)it can be the fuel pump or the suction line from the motor base i hope it will help
Posted on Sep 20, 2009
  • 9 Answers
SOURCE: i own a 380 gtx ski-doo,which just started blowing
its not water tight - make sure all seals and gasjkets are in place
Posted on Dec 20, 2009
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
  • 677 Answers
SOURCE: Sea doo jet ski won't get full throttle. It idles
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
Posted on Feb 03, 2010
SOURCE: my 93 ski-doo mxz 470 has trouble starting/when it
recoil rope routing?
Posted on Jan 28, 2011
How do I remove the battery from a 2014 Ski Doo 900 ace snowmobile?
About 26,400 results (0.92 seconds) Search Results
    Brp Expert Tips For Summer Snowmobile Storage ' Ski-Doo ...
    xteam.ski-doo.com/en.../brp-expert-tips-for-summer-snowmobile-storag...
    Apr 4, 2013 - BRP Expert Tips for Summer Snowmobile Storage ... If you have a 1200 4-TEC or ACE 600, change the engine oil and filter. ... SnowTech's First Impressions of the ACE 900 Engine .... September 2014 (4); August 2014 (1); July 2014 (1); April 2014(2); March 2014 (6); February 2014 (14); January 2014 (5) ...
    First oil change opinions - 900 ACE 4-Stroke Models - DOOTalk ...
    www.dootalk.com/forums/topic/671977-first-oil-change-opinions/
    Dec 15, 2013 - Page 1 of 4 - First oil change opinions - posted in 900 ACE 4-Stroke ... suppose to be easier on the 2014 , different battery bracket ? or you can ... 900 Ace Summarization ??? - 900 ACE 4-Stroke Models
    Apr 1, 2014
    900 ACE no power at outlet - GPS Talk
    Jan 15, 2014
    2013 Skandic WT 600 ACE - Skandic / Expedition
    Dec 22, 2012
    Battery Removal - Skandic / Expedition
    Apr 12, 2012
    More results from www.dootalk.com
Jan 24, 2016 | Ski-Doo 2014 GSX LE 900 ACE
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
How to tell the skis apart from left to right
Good day.
You can't tell, just make sure all the openings are sealed by the shape of the gasket and the gasket is not blocking any wholes.
Good luck.
Jan 19, 2014 | Winderosa Exhaust Valve Gasket Kit -...
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
See doo wont start
It should start on land more easily than in the water (no drag on impeller). However, you should not run your boat for more than 10 or 15 seconds dry or you might damage the motor (too much heat build up). If you put a flush kit on your boat you can run it as long as you want in your drive way. We always start are boats on the trailer for a few seconds before launching. It makes the first in the water start a lot easier.
Apr 02, 2010 | Encore Software Kawasaki Jet Ski...
Problem startin the game
maybe the is not installed correctly try to reinstall it or if the is pirated than it is corrupted
Feb 17, 2009 | Simon & Schuster Ski-Doo: X-Team Racing...
Winter Sports Logo
44 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
