Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet 8182748 door is open and won't lock closed. it looks like the latch is in the closed position. is there a reset or some other solution.
  • 3,230 Answers
You need to change the door lock assembly.
Good Luck!!
Thanks
Posted on Jun 14, 2009
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Washer door wont latch ghw9200lw duet
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door will not close on whirlpool duet front loading washer?
The machine may have locked open. hold the sound charm for 3 seconds and it will unlock. u can also fake out the machine and pretend u are starting a new cycle, when it starts, hit cancel once. you will then here the machine unlock. after that, unplug the machine to reset it and you're good to go.
Feb 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Latch stuck after each load
Hello bittoner
Welcome
You said,The latch remains in the door closed position after each load. I can manually reset it by taking the cover off and it works fine until after it runs a cycle and I open the door again. Is this a latch problem or a electronics problem. Note, I have replaced the latch assembly about a year ago for a different reason
Try to turn off the breaker for the washer for 5 minutes and see if the system reset.
If not the electronic door switch sensor is bad
Let me no how it goes.
Huuum
Please remember to leave a rating!
Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
