DIN plug output symbols
Ther are four DIN output sockets on my Grundig TK146 reel-to-reel recorder. I need to know which one I can connect to my PC for transferring to CDs. Any ideas? I'm not sure what the symbols alongside each socket mean.
Brian
  •  Grubhead
    Grubhead May 11, 2010
    Can you describe them?
2 Suggested Answers
  • 5 Answers
SOURCE: Record from tape deck to computer via USB and Audacity software
Im not sure what DIN sockets you're trying to describe here, but quite often, you can record from a tape player to a pc by connecting an rca cable to an adaptor; rca to 1/8"(headphone pin) and then plugging that headphone pin in to the microphone input on your computer.
Posted on Jun 22, 2009
Grundig tk5
With a bit of luck you may be able to find some adapters to allow a plug into the Line IN port of the computer.
Here is a site that appears to have the Grundig manual if you register ( its free). There may also be some very knowledgeable people there that you provide the info you need.
Oct 29, 2013 | Audio Players & Recorders
Why don't i have a connection when i connect my laptop to the TV?
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Mar 01, 2010 | Toshiba Satellite Pro L300 Notebook
Can't use the tv as a computer moniter.
Feb 28, 2010 | Venturer PLV36220S1 22 in. LCD TV
Cant hook up laptop to tv
Feb 28, 2010 | RCA L40HD36 40 in. LCD HDTV
I want to install a sony dvd player to my curtis flat screen ty
Feb 14, 2010 | Televison & Video
Try to connect Samsung lcd hdtv using pc cable. I click source, PC and enter but no picture.
You must set it all up first. It seldom "Just works" At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
Feb 10, 2010 | Televison & Video
How to connect laptop to ILO-32 for use as monitor
Feb 10, 2010 | iLO 3200 32 in. LCD Television
Jun 22, 2009 | Audio Players & Recorders
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
152 people viewed this question
 Grubhead
Grubhead
