Question about NEC PABX SL1000
Long conversation cut off reset
Resettinjg
Connection to XBOX Live is not good
Hi!
Who is your internet provider and are you using an ethernet cord or a WiFi connection?
Thanks.
Jul 21, 2017 | Arris Surfboard Cable Modem Sb5105
Tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
on Jul 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
2.7 cutting off
The battery has nothing involving a reset
I don't think you understood the conversation
You don't drive a car that shuts off & have no problems
If any drive cycles were necessary he would write it down
& explain to you.
Take it back & get more involved in the educational part
Nov 22, 2012 | Dodge Cars & Trucks
Hi, my heater was converted to natural gas yesterday. it works for about 5 minutes then cuts out, flashing the number 13
The Error Code 13, indicates a combustion fault. In other words, the heater is not lighting properly. This may be a problem with the conversion from one gas type to another. Particularly, if not all things were reset for Natural Gas. It does require a service call to check and repair the problem.So, whom ever did the conversion for you, owes you a service call.
Hope this helped you. Please let me know. Cheers
Jul 06, 2011 | Rinnai Heating & Cooling
For no reason at all my phone turns itself off i may be in the middle of a conversation, I was trying to watch a video and it just cut off and another time i was trying to text someone and it just cut off...
well if it has not been dropped or water damaged then its a software issue if this is the case you will need to export contacts to sd card and do a factory reset after it resets completly and reboots pull out battery and reinstall battery do not turn on yet hold volume down then hit power button when you get to 2 e recovery reboot system this is more that just reseting phone your rebooting your os that should take care of you save all pics and numbers to sd card or you will lose them
May 05, 2011 | T-Mobile My Touch Cell Phone
My uniden cordless phone CXA15198- is cutting off in the middle of conversations
My Uniden phone system CXA15198 -one base phone and one cordless was cutting off the conversation. I unplugged the phones for about an hour and since then they've worked fine. Next time it happans I'll get a new battery for the cordless phone.
Dec 27, 2009 | Uniden Lands Phones
How do I put second call on hold while finishing first conversat
FIRST U HAVE TO HOLD FIRST CALL. AND TAKE THE SECOND CALL.THEN HOLD SECOND CALL.FIRST CALL AUTOMATIC ACTIVATE.OK
IF HELPFUL THEN PLEASE RATE
Jul 10, 2009 | Uniden DXI8560-2 Twin - - Phone
Cut off in mid conversation
try having the phone firmware reflash to correct this error, try a mobile service center to have this done.
Oct 26, 2008 | Nokia N95 Cellular Phone
My calls will get dead /cut off once in every 10 calls averagely N95
try to reset the phone,sometimes it works!
or use this reset code (*#7780#)
if it does'nt work try it manually go
to menu, settings etc..... :-)
or if still thesame
try this full reset code...
but backup everything first
specialy contacts....
code (*#7370#)
it will restore everything....
Nov 21, 2007 | Nokia N95 Cellular Phone
NEC PABX SL1000 Logo
24 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
