Question about Furniture
Bush official website
We have aBush 4.1 CH150W Soundbar connected to a Samsung 43" TV thro' the headphone socket. Keeps losing sound for a few seconds.
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
  • 1894 Answers
SOURCE: How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
Posted on Mar 09, 2009
milkburp
  • 416 Answers
SOURCE: lg lcd tv 37lc2d no headphones socket - how do i
You can purchase a cable to connect to the Audio Out ports on the back of the TV. It will have 2 RCA connectors on one side that plugs into the TV and a 1/4" stereo jack on the other end that you will connect your headphones to. You could even pickup a pair of wireless headphones... they will have a volume control on them! I hope this helps.
Posted on Mar 17, 2010
SOURCE: My Mother has just received a Bush LY24M3 LCD
i have just bought this tv myself, very good but ive checked it over and there is no headphone socket
Posted on Oct 10, 2010
jerry_kramer
  • 3904 Answers
SOURCE: How to connect a samsung soundbar to my tv and sat and dvd
Feed the audio from the audio out on your tv to the receiver. Plug your sound bar into the speaker output of the receiver and you should be up and running. You will have to turn on the receiver and control the audio there. The TV may have a setting for external speakers that you need to turn on in the audio menu. Now this is the straight forward approach but there are many factors to consider. One example would be the amplifier output being compatible with your speaker so you don't blow the speaker or the amp or amp/receiver combo.
Posted on Sep 28, 2012
Samsung soundbar with sub woofer
Maybe try headphones settings instead of internal speakers and consider the sound bar as headphones. Some TV's may limit output to headphones as well but start there.
Assuming you have a Samsung TV, look at your TV settings.
You may have the sound level on auto.
Next check to see if you are set for the external speakers, you might have to look in additional settings to find this.
Should you have another brand of TV the concept is the same.
so check settings for TV for external output.
Sep 01, 2016 | Samsung Audio Players & Recorders
How do I connect a soundbar to my polaroid tv it only has a headphone out .the sound isn't very good
The coax out is a digital sound output. You can not use that on your soundbar. The sub out is for hooking the tv to a subwoofer (bass only). You gonna have to use the Headphones output, buy a good 3.5mm to rca cable preferably one with a built-in noise filter so it can attenuate the "hum". Also try lower the volume on the TV so you can have less distortion. That's all!
Apr 15, 2015 | Polaroid Televison & Video
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
Why doesnt my goodmans soundbar work? It is connected to aux on tv and soundbar only makes buzzing sound
The AUX sockets on the TV are for sending a signal in to the TV. This is what's known as an input.
Signals don't come out of any socket that is labeled in or input. If you want signals to come out of a device, then the correct socket to look for is labeled out or output
The cheapest way of connecting your flats screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
Sep 08, 2014 | Televison & Video
LG sound bar don't work on LG tv
Need models of TV and soundbar to be more specific.
Generic help: Not plugged in correctly (you connected to the TVs red and white sockets without realising that they are a "signal in" and not a "signal out" type socket. Incompatible (i.e. a soundbar that uses ARC but the TV doesn't have it). Wrong TV settings - You're connected to the headphone jack but you didn't bother reading the manual that tells you there's a separate control for audio out via that jack and it's buried in the menus. The list goes on.....
Read the manuals, and don't just guess where things plug in. That's always a good start.
Sep 07, 2014 | Televison & Video
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
Trying to connect samsung soundbar to Technika tv. Plugged aux cable (red and white) into tv then other end (black) into the soundbar. Still no sound.... Help ?
Hi probably a silly comment - have you connected to the AV in or Out sockets on the TV? Worth checking? also do you need to select an audio profile on your TV in order to divert from the internal speakers. Worth looking at your sound preferences on your TV
Jun 24, 2014 | Audio Players & Recorders
I can only get sound through headphones and not tv speakers
Check the speakers. If found OK, check and repalce headphone socket.
Aug 07, 2013 | Bush Televison & Video
How do I connect my LG 32LD350 to a samsung HW-E350 sound bar? My tv does not have audio out jacks.
Sorry but you cannot do this with this tv.. You need hdmi 1.4 support and you only have 1.3 the only way i have heard of it being done is through the headphone socket to a 3.5 jack to the aux socket on the soundbar.... johnB
Feb 22, 2013 | Samsung HW-E350 Crystal Surround Air Track...
I want to connect my mp3 player to either my soundbar or flat screen. How would i go about that?
Hi
You don't identify your make and model of MP3 player or your Flat Screen TV.
Some types of MP3 player can dock into a device (MP3 Dock) that has audio output connectors that can connect to either your TV or your Sound Bar with either standard stereo phono or HDMI cables (your TV has HDMI capability).
If no dock is available for your MP3 player, a stereo phono to 1/4 inch stereo jack will connect either audio Out or Headphone Socket to your TV or Soundbar. The sound quality may not be the best with this type of connection but it should be adequate.
A retailer like Radioshack, Best Buy, PC World, Maplin, etc. (depending on where you are) should stock these MP3 Docks and cables.
Hope this helps.
Aug 24, 2011 | Vizio VSB210WS Soundbar
Furniture Logo
64 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
