Question about Sony PCM-D50 Handheld 24/96 Recorder
Powerboard problem Sony pcm D50 not working due to power board problem
3 Suggested Answers
dduncan774
  • 760 Answers
SOURCE: What's your problem?sony v444es 5,1 wont turn on, only clicks the relay on power board non stop
Sounds like your power transformer is bad. You might also check the power board for cracks. This model had a history of that.
Posted on Jun 22, 2012
ebminor
SOURCE: Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and
You can reset the device by entering TEST/SERVICE mode. With the device off, turn the LIMITER switch to the off position. Turn on the device, hold A-B and DIVIDE while turning the LIMITER switch to the on position then release. Use FF or FR to scroll through the menu to Key Chk + Format. It'll ask for you to enter 18 key presses. Press FF,FR,MENU,LIGHT,STOP,PLAY,DIVIDE,REC,PAUSE,DISPLAY,A-B,DPC,HOLD,LCF,LIMITER,INPUT,MIC ATT, MIC L+R POSITION, and lastly turn the power off and on.
Posted on Sep 26, 2012
KDL-60W850B LED blinks 3 times, wont turn on
I would repair the power supply or the fault that is causing it to fail.
Apr 18, 2018 | Sony Televison & Video
I have an LG 42 TV that powers up and only shows black screen.
Chances are you have some open LED's, if one opens the entire strip will go out as they are wired in series and the power supply is shutting down the LED circuitry due to improper current or voltage
Nov 15, 2017 | LG Televison & Video
How do I fix my PCM-M10 Sony audio recorder? I haven't changed the batteries for a while and it looks like they are corroded. The recorder won't switch on. Is it fixable?
Carefully remove the batteries and remove the corrosion. Outdoor is better to reduce being exposed by breathing it in. After removing corrosion, add new batteries and try again.
Oct 03, 2015 | Sony Pcm-d50 Portable Linear Pcm Recorder
Sony pcm d50
I also have had the exact problem with my PCM D 50`s (I have 20 machines because I teach radio journalism). 8 of my D 50`s are not working. They don´t start, freezes and nothing helps. I´ve been in contact with Sony and they say it´s a problem with "the power board". What´s the problem, they will not tell. It would cost me about 300 dollars to fix the problem. Instead I´ve bought new Sony M 10 for less money. They work just fine.
Dec 13, 2013 | Sony PCMD50 (4096 MB 125 Hours) Handheld...
Pcm d50 common trouble
best solution is to contact sony advise try an dget a replacement
Jul 26, 2012 | Sony PCM-D50 Handheld 24/96 Recorder
Jun 21, 2012 | Sony STR-V444ES Receiver
Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and 20 attempts to boot up. Once on, if the unit is left idle for more than 6 seconds, all the controls will freeze - it will not even switch off. The only way...
i dont have a solution but this seems like the only way to contact a user. im experiencing the EXACT same problem right now with a pcm d50. Did you ever figure out what to do?
Apr 29, 2011 | Sony PCMD50 (4096 MB 125 Hours) Handheld...
My Sony PCM-D1 recorder recently behaves erratically by sometimes failing to record on both channels using its built-in microphones.
I'd contact the service beforehand. If you think, that that behaviour was due to a software, ie. firmware issue, google for Sony PCM-D1 service manual. I wouldn't precisely describe the procedure, but generally a some ten-click-sequence is required for entering the service mode which allows for factory resetting the recorder. I don't think that the reset procedure can harm the device, but for example, if one attempts to reflash the firmware and the prodedure fails - due to power problems, for example but also due to other things which could happen - then the PCM-D1 could be regarded as busted. The repair includes qualified service with SMD repair facilities and a new board to replace that failed one. Therefore such a complicated service mode sequence, just as a precaution I think.
All the best,
Edi Zubovic, Crikvenica, Croatia
Nov 26, 2010 | Sony PCM-D1
Need to find a power/battery charger board for Acer Ferrari 4000.
Hi there.
You will be able to get the laptop powerboard from ebay or Sony themselves, although if you get from Sony it will be considerably more expensive.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Acer Computers & Internet
Need driver
Try here:
http://www.sony.net/Products/DP-driver/Mac/index.html
Apr 12, 2008 | Sony UP D50 Thermal Label Printer
Sony PCM-D50 Handheld 24/96 Recorder Logo
169 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
