Question about Canon Ink Cartridge GPR15 for iR 2270, iR 2870
PRESSER ROLLER CUT AFTER 20000 COPIES WHY
CANON 220 VOLTS
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 142 Answers
This is a low number for that roller.Check the bearings make sure they are not seized. If you have experience a noise then most likely you have bad bearings and the roller is not rotating correctly. The guides may have built up of toner and touching. the seperation guide plate not in correct position or knocked off .under the roller dirt and grime needs to be removed. something is touching the roller causing this and you will get better life from a OEM roller.
Posted on Nov 14, 2015
While printing or photocopy the print in some copies is tilted in some copies it is straight.
check the paper guides in the casete . or clean the feeding rollers with alcohol
Apr 20, 2016 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Canon IR1024 black line down 1 side of copy
How many copies did machine make? Could be a drum unit,transfer roller or fixing film in fixing unit
Sep 18, 2014 | Canon IR1024 COPIER FOR 220 VOLTS
Canon ir3570 errorcode e0007
u have to need replace ur fixing film
Jan 11, 2013 | Canon IR3570 COPIER FOR 220 VOLTS ONLY
Powder spray in first copy only
clean gently the charging roller with cloth or better to replace the charging roller
Sep 18, 2012 | Canon imageRUNNER 400S Copier
Convert 110volts angle grinder to 220 volts
change armature stator 220 volt
Jun 30, 2012 | Saws
I am facing frequent tearing of fuser film code 00007.The engg. advised n converted 4570 canon to reduced speed approx 30-35 copies per min. but the problem persists after every 18000-20000 copies .Please...
if the fixing film keeps to wear down rapidly, the problem can be few things.
  1. Maybe the pressure between fixing film and silicon roller isn't good ( replace silicon roller, silicon roller bushings, and execute the nip check in service mode )
  2. Maybe that the fixing film isnt Canon and therefore lower quality.
  3. Maybe the fixing heater ( beneath the fixing roller ) has "nose" or place where the fixing film gets stucked or wraped. Change the fixing film assembly ( Canons film + heather in assy )
  4. TO BE SURE, THE BEST SOLUTION IS TO CHANGE THE WHOLE FIXING ASSY with new one.
Hope that helps!
PS for service manual you leave your e-mail...
Aug 01, 2011 | Canon imageRUNNER 4570 Copier
Canon PC921 copier has blurry section on copy
what you probably brushed over was the transfer roller(black and spongy?). first try running 20 or 30 blank copies through the machine. If that doesnt work take a dry paper towel and gently wipe and rotate that black roller. that should take care of the problem. If the roller needs replaced you should have a technician do it. You could break the machine beyond repair.
Apr 07, 2009 | Canon PC-921 Black and White Copier
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Canon Ink Cartridge GPR15 for iR 2270, iR 2870 Logo
126 people viewed this question
old marine
old marine
