Question about Dell Vostro 1500 Notebook
Screen dim Same problem. Screen would work part time and then switch to gray with faint images in the background. Same time frame too, just over a year old by approximately 3-4 months. So, is this the inverter, backlight or both?
    President:
  • 2,653 Answers
It could be both. But usually it's this order:
inverter, backlight, lcd, video card, lcd cable.
I always start by checking out the inverter first since it's the easiest as well.
The cheapest place to get a replacement is eBay for sure.
Best of luck!
Posted on Jun 14, 2009
T v problems Gray image in background
Sounds like a burned screen. Contact the authorized service center for Toshiba, or any experienced service technician. This is a repairable fault; but need experience to do.
Gopakumar Gopalan Google
Mar 12, 2014 | Toshiba Televison & Video
Pew71 display suddenly dim
did you also replace the inverter??long ish piece of board two long wires attached.this is used to light the bulb on the screen,also if you turn the pc to a light when switched on can you see any image will be faint???if you can it will be the inverter..also the screen you put in are you sure the light works. hope this helps
Dec 12, 2013 | Acer Computers & Internet
My 2 year old viore led tv model led32vh30 has a grey screen with the image faint in the background. Any home fixes would be great. Thank You Kyle
unfortunately the faint image can not be fixed it is caused by the light burning it into the screen due to the image being static you need to replace it
Nov 03, 2013 | Televison & Video
Sony Vaio E Series VPCEH37FX screen goes dark, but fine otherwise
If you can see faint dim images on the screen, then your back light or power inverter has failed. They are not adjustable or repairable and must be replaced. If you can't see anything on the screen, the LCD has failed and must be replaced. Sometimes it's hard to see the dim images so use a flashlight to help determine if there is any image on the lcd.
Oct 27, 2013 | Sony VAIO Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
READ MENUS FINE, LENS OPERATES FINE, OTHER STORED PHOTOS READ GOOD, BUT CAMERA SHOOTS ONLY BLACK FRAMES, NO SCREEN IMAGES WHEN SETTING UP A SHOT. WHEN HELD UP TO THE LIGHT THROUGH THE LENS, A FAINT GRAY...
woowww man i think youv got a lot probs with you camera,mainly if there is a a black frame in you screen i think your screen monitor is damaged so ull have to replace it...... and da black frames is a fault in da camera itself.according to wot i understand i think the shutter speed is not corresponding with da software in da camera um sorry but dese repairs are gonna cost ya.... best tin is to give it to a repair shop or service personnel for further clarification
May 30, 2011 | Cameras
Faint image in the background.
Hi Nate,
The same thing has happened to me before.
Well, once you drop your laptop a lot of things could go wrong. From a broken driver to a cracked screen. I believe you broke your bulb. And the cells of your laptop are kinda messed up we can say. Yes, this is fixable but will take time. I hope everything goes better!!
Good Luck
**dont forget to rate**
Jul 10, 2009 | HP Pavilion xh555 (F3929H) PC Notebook
My acer 9300 when switched on shows a blank screen (black with some faint white back ground) but the process of starting windows goes normally coz i can view this when connected to a monitor whats a miss ?...
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Acer Aspire 9300 Notebook
Display is very faint, disappears
replace the inverter board below the lcd panes  with same part number.if it is in india i can help you
Mar 10, 2009 | Dell Latitude 110L Notebook
Dell Vostro 1500 Notebook Logo
160 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
