Question about Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE
Kenmore dishwasher water inlet valve replacement
How to replace water inlet valve
    Scholar:
  • 132 Answers
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Posted on Aug 05, 2014
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
My Kenmore dishwasher is making a grinding noise during the wash cycle
see this causes:
Water-inlet valve
test the inlet valve for defective and replace
Motor
bearing worn replace
Heater fan
bearing worn, replalce
Pump open the pump and take out the sediment, or debris inside, or replace.
Jun 18, 2012 | Kenmore Dishwashers
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
Water comes to the dishwasher but will not go into the dishwasher?
Hello & Welcome to FixYa
When the water comes however, won't go inside the unit then it indicates that the problem is either with a clogged/blocked inlet valve or the water inlet valve itself has gone bad and needs replacement. You can also test two terminals of the water inlet valve before replacing it. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore 15129 Built-in Dishwasher
My Kenmore 15882 dishwasher continues to fill with water. We keep pressing the cancel button to drain the water. Any ideas?
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | Kenmore Dishwashers
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Top arm not spinning
Check the operation of the water inlet valve - it is probably faulty, not passing sufficient flow of water.
Fix by replacing water valve unit.
A faulty water inlet valve is the most common fault on dishwashers.
Oct 16, 2009 | Kenmore Dishwashers
KENMORE DISHWASHER WATER DOESN'T SPRAY.
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Dec 05, 2007 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore dishwasher 665.1671590
Did you have this problem before replacing the solenoid coil or it start after ? In case it started after solenoid coil replacement, its look like you did something wrong while assembling it back. Disconnect Dishwasher power cable and close water tap - remove the selenoide coil, clean the valve from scale or other dirt and check that you placed all parts back properly (spring,gasket...). Good luck !!
Jun 06, 2006 | Kenmore 15129 Built-in Dishwasher
Kenmore Elite 24" Built-In Dishwasher with Ultra Wash HE Logo
146 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
