Question about NEC Lands Phones
My phone says initialize
I'VE MOVED A PHONE FROM ONE POINT TO ANOTHER AND THE PHONE NOW JUST SAYS INITIALISE - WHAT DO I NEED TO DO?
I have a NEC DTH-8D-1 Corded phone. I moved my desk and plugged the phone in at a different phone line port and the screen now reads "Initialize." What is it asking for? How do I set up my phone at th
Your extension is hardwired to 1 jack, if you plug in somewhere else you'll be lucky if the jack is active with another extension. Someone needs to re-wire your extension in the phone room to your new jack. If it won't activate but says Initialize, then that jack probably has a live fax line or analog extension, but not a digital line that works on your phone.
Sep 02, 2014 | NEC DTH-8D-1 Corded Phone
Porsche Cayenne - Command System. Phone failure
I would suggest you discuss this with the dealer.
Mar 17, 2014 | Porsche Cayenne Cars & Trucks
My nokia phone not supported to view youtub videos
If you can't play videos once you've successfully installed the YouTube for Mobile app, one of the following issues may be causing the problem:
  • Your phone may not support streaming video. Check by trying to play a video at http://m.youtube.com
  • Your streaming video access point may need to be configured outside of YouTube for Mobile. Depending on your phone and mobile data provider, this access point may need to be the same or different from YouTube's. For more help with these settings, please see the "Access Settings" article.
  • If you've successfully played videos with YouTube for Mobile before, your network connection may not be strong enough at the moment. Please try again later.
  • Your carrier might block RTSP traffic which is required to transfer the video.
    hope this helps
Feb 29, 2012 | Nokia Cell Phones
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
I have lost my instructions for programming frequently used numbers into the phone.
http://www.amazon.com/Panasonic-KX-TSC11B-Corded-Phone-Caller/dp/B0007Q3QSK
Above is your instruction book,moved down the page till you get to "product details".There you can download your manual.
Hope i`ve helped
Nov 27, 2009 | Panasonic KX-TSC11B Corded Phone...
My mains charger won't go into nokia 6300 can I get it repaired?
nothing has moved in the phone but the charging pin inside the charging point has got pushed inside the phone
go to any nokia repairing shop & if your phone is under warranty it will be repaired free of cost.
pls rate me
thankyou
Feb 14, 2009 | Nokia 6300 Cellular Phone
Audio problem in head phines
YOUR PROBLEM IS NORMAL. PLS. CLEAN THE CONNECTION POINT BETWEEN YOUR EARPHONE AND YOUR PHONE. IT MUST BE RUSTED SO CLEAN IT PROPERLY WITH A POINTED PIN AND RETRY TO USE YOUR EARPHONE(HANDSFREE)
IF THE PROBLEM IS STILL EXISTS. THE WIRE OF YOUR HANDSFREE'S WIRE MUST BE DAMAGED BY USING IT UNPROPERLY. SO IN THIS SITUATION YOU NEED TO CHANGE YOUR HANDSFREE WITH A NEW ONE. THIS WILL SOLVE YOUR PROBLEM
REGARDS
KETAN PATEL
Feb 04, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lands Phones Logo
114 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
