Question about 2003 - 2005 Jeep Liberty Engine Timing Idler W0133-1671403 Jee
Lubricate a new 3.7L chrysler engine before first start up.
How to properly lubricate a new 3.7L chrysler engine before first start up. by hand without an oiler
    Sergeant:
  • 361 Answers
If the oil pan and valve cover are on it just put oil on on the mains lifters rocker arms crankshaft etc and use plenty did you soak your lifters in oil for a day so the get filled with oil , and if it is all closed up really do not have to worry about as you said turn it by hand a few times around that should be fine ,just do not run at high rpm until it had break in time , good luck
Posted on Mar 29, 2014
How to replace a oiler?
Wow, an 031 AV and its still running ?? You really got the life out of that one !!! The oiler is mounted on the outside of the block around the crankshaft behind the sprocket. Bar and chain, sprocket and another side cover must come off first. Make sure you blow everything clean with a air compressor during disassembly, because its gonna be gnarly under there.
There MAY be two different types available: one with adjustable oil flow and one without. I would NEVER go with one that is NON-adjustable. Once done, pre-lube your bar and chain with oil prior to starting the saw. This prevents a few hundred revolutions of the chain without lubrication before the new pump gets oil through the delivery port.
Closely monitor the oil tank during the first tank of fuel going through the saw and adjust the oiler toward the minus (-) just a tad bit if the oil tank runs dry BEFORE the gas tank.
Jun 11, 2014 | Stihl Service Manual for 031AV Chainsaw...
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
Fan does not spin without me helping it get started
Depending on which fan you are referring to, that motor should be replaced. A little lubrication will help. I use a zoom spout oiler, it is turbine oil. This can help keep the motor going until a new one can be installed. I have seen the oil sold at Home Depot lately and some ACE hardware stores. As a refrigeration tech, I have used this oil for many years.
Jun 17, 2011 | True GDM-10 Refrigerator
When I start my 2004 Pacifica;everything is fine, but as I drive care begans to heat up. Coolant is new,oil recently chnaged. What do I do ?
It is very probable that your thermostat is stuck. The thermostat, when operating properly, regulates the temperature of the engine. As the engine heats and comes to proper temperature the thermostat will begin to open allowing the warm/hot coolant to travel to and thru the radiator where it then is cooled and pumped back in to the engine. At times the thermostat may stick (even open a bit) and cause the engine to overheat. The good news is this is an inexpensive part @ $5 - $10 which will include a new gasket. One way to check this is to let the engine come to heat (do not let it over heat) as it warms place your hand on the radiator...is it getting warm too? if not (or just a bit of warmth) the thermostat is probably your issue. Please be carefull to keep your hands away of rotating parts and any fans that may start without a warning.
I hope this may have helped,
Tom
Oct 21, 2009 | 2004 Chrysler Pacifica
No oil from chainsaw
Remove the chain and bar. Run the engine and observe the oil discharge port--any oil coming out? If so, clean the drive end of the bar and pay attention to the oil ports into the chain path. If no oil comes out, then the pump or oil lines are the indicated problem. Good luck!
Sep 01, 2009 | Garden
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Aug 23, 2009 | Poulan Garden
Wrench Troubleshooting
In line oiler Lubrication is critical to extending the life of your valuable air impact wrench and increase productivity. An air tool that has not been properly lubricated will result in low power output. The usual culprit is a dry motor starving for some oil. Your impact wrench is an expensive investment and you must take the time to properly lubricate it. The easiest and quickest way to make surein line oiler it is constantly lubricated is to install an in line oil lubricator. One of these will insure your air tools are receiving oil every time they are used. In line lubricators attach right into the air hose and you fill them with the correct lubricating oil. (see your manufacturer's specs.). You should also do routine external lubrication through the hammer case grease fitting. A well lubricated air impact wrench will deliver more torque, last longer, run quieter and increase productivity. Don't forget to add an in line oiler to your next impact wrench or air tool. It will pay for itself several times over.
Aug 27, 2008 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Wrench Maintenance
Aug 27, 2008 | Campbell Hausfeld Maxus 3/4" Impact Wrench
2003 - 2005 Jeep Liberty Engine Timing Idler W0133-1671403 Jee Logo
65 people viewed this question
Top Gates Vehicle Parts & Accessories Experts
Lodhi Autos
Lodhi Autos
Walter Turteltaub
Level 1 Expert
Bill Boyd
Are you a Gates Vehicle Part and Accessory Expert? Answer questions, earn points and help others
