Question about RTO Toys
Check a bobcat 463 glow plug relay
Should I get and buy the part and replace just because?
snownbird33
  • 120 Answers
SOURCE: Glow PLugs and Relays
Good Day
The glow plug relays are located on the right front shock tower. Remove the cover and you will see two relays If I remember I think they are round, but not sure.
Please let me know how you make out and if there is anything else that I might be able to help you with.
Cheers
Posted on Sep 17, 2008
  • 119 Answers
SOURCE: volks wagen golf diesel tdi Nreg
Check the glow plug thermo sensor...found in the cylinder head.
Unlightly anything wrong with injector pump.
Good luck
John
Posted on Feb 27, 2009
  • 102 Answers
SOURCE: 2002 Jetta TDI check engine light
very common for the harness that plugs onto the glow plugs to have too much resistance it will still work but will set codes
Posted on Mar 23, 2009
joecoolvette
  • 5660 Answers
SOURCE: Can anyone tell me where to find the glowplug
Above the Relay Panel is the Auxiliary Relay Panel. Has thirteen positions in it.
6 across the top, 7 across the bottom.
Across the bottom the Glow Plug Relay is the fourth one over from the left. It is Number 10.
(180)
Posted on Sep 17, 2009
  • 320 Answers
SOURCE: No power to glow plugs...relay replaced...still no
There is a big fuse in the engine room for the glowplugs.
You'll find it just near the brake vacuum cilinder under a black cap...
Hear if the glow relay ticks when you'll put power on. Does the glow light lights on?
Posted on Oct 31, 2009
I have a 08 bobcat 463 with a Kubota engine. it will not start I checked fuel shut off solenoid its good cracked lines at injectors have fuel. sound like it wants to start lot of black smoke
That black smoke is because it isn't getting any air to mix with the fuel your putting in it. Your air cleaner is either plugged up completely or there is a emergency shut of flap on the intake that needs opened.
Jun 25, 2017 | Cars & Trucks
How do i replace the glow plugs on my 773 bobcat
There a small plug with wire on it right a round injectors. Take 5/16 socket ( i think) screw it out
Nov 30, 2014 | Bobcat 773
Where is the glow plug relay on a bobcat 753
all fuses and relays under seat in foot control area
Nov 13, 2014 | Cars & Trucks
On a Bobcat 463 when starting I normally hear a click just before starting. Now there is no click and it won't start.
That unit runs on diesel. The click could be a fuel pump relay or injector pump or injectors retracting.
Aug 03, 2013 | Bobcat Welding Tools
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
Tried to start 2004 f250 with out glowplugs now it wont start. checked fuse still wont start
glow plug light and glow plug are not on same system
check at gow plug conection (top of valve cover both side
follow from relay front valve vover right side silver box)
power 12 volts on all 4 wires in both conector left and right
if not replace relay if 12 volts relay ok (test light clip on ground)
then check glow plug (test light clip on positive ) touch wires going
to glow plug should light up if ok (quick test ) if any fail replaced
if all seems ok look at the oil injection system most common
problem with these motors I have yet to replaced a glow plug or relay
Sep 30, 2010 | 2004 Ford F350
Can anyone tell me where to find the glowplug relay, it's a 7 prong relay, on a 2002 vw beetle 1.9 diesel no turbo ? allready been under the dash and checked all the relays, none of which are 7 prong,...
(180)
Sep 17, 2009 | 2002 Volkswagen Beetle Turbo S
I have a 1997 ford F350 WITH A 7.3L DIESEL, it turns over but will not start. My wail to start light or other indicator lights do not come on when I turn on the key.
The first thing to do is locate the owner manual.
Look for the glow plug relay MAIN FUSE location.
The glow plug portion of your van is not working.
This difficulty scale from 1 to 10 is a 9.
You will need a DVM and tool undo the cables to each glow plugs.
It's a 1 to 2 hours troubleshooting job.
I'm going to fire off a quick list
Check / replace blown glow plug relay main fuse
Disconnect each center nut of the glow plug wire. PLEASE CHECK ONE AT A TIME.
Read the resistance between the center of the glow plug and the metal base of the plug.
Please take good note on each glow plug resistance reading.
MAKE SURE all cables are put back and tighten properly.
Compare the resistance on all cylinders.
OPEN/high resistance is bad glow plug.
In general 3 ohm or less is OK.
You should buy one and use its value as baseline.
Glow plug relay can be bad.
You will need the VOM and a friend to turn the key.
Check the voltage to each glow plugs. It should be 12.6-13.6 volt.
Be careful,the plugs will get HOT.
Compare the voltage on each cylinders.
So the problem can be combination of
glow plug relay
glow plugs
ignition switch is unlikely but I'm going to list it anyway.
Once again,this is a difficult and time consuming job. I will ask a friend to help out,
Good luck.
Jul 23, 2009 | Ford F-350 Cars & Trucks
2002 Jetta TDI has no power to glow plug buss at startup
replace the relay but check connections first as often connection get hot and corroded.failing which buy a push button switch use a relay and and some heavy wire to and from relay to the heaters and work them manually.you could try seperating the relay and cleaning the connections inside.
Oct 22, 2008 | 2002 Volkswagen Jetta TDI
Toys Logo
41 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
