Central air system notworking
Thermostat ok at least for heating. Signal goes to condensingunit and blower turns on. Need info on checking electric circuitry at condensing unit.
  • 2 more comments
  • caleb470 Jun 14, 2009
    I need an expert who knows about Trane Home air conditioners. Model TTR742A100AO.
    Dou know how to add refrigerant to a TRANE condensing unit ?
    I wish to add refrigerant to my TRANE home central air condensing unit. Please do not reply unless you have the experience to do so.
    Thank you.
    james, ty. are gage manifolds rentable? Should this be done at the condensing unit?
  • 614 Answers
You will need gages and temp meter to add refrigerant plus R22. Flare cap on large is the suction low side line. Put low side gage on there. Start unit .Your suction pressure should read about 70 to 75 if the house is very warm. Add refrigerant until this pressure is reached. You need to read the temp of the large line. It should not be below about 54 degrees. Normally. If you have not done this before be very careful to much freon will damage compressor. You have a leak somewhere if you have to add gas. Make a note of how much you add and when. Gives a base line to go by. Rusty
Posted on Jun 14, 2009
  • James Stopp
    James Stopp Jun 14, 2009
    You may be able to rent the gages at a Tool rental store but the refrigerant is another problem. You have to have EPA card to buy R22. But if you know someone who has some use it.
    Sergeant:
  • 296 Answers
Hi,,
Here are more details in addition to the prior techs articles.
www.fsec.ucf.edu/.../FSEC-CR-1044-98/pvres2.htm
Thanks
    Brigadier General:
  • 3,917 Answers
Please check this article. It gives a fair idea about the cirfuitry.
www.flagshipmarine.com/chiller.html
For a more techinical know this would be best:
www.miata.net/garage/CoolingSystemProblems.html
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Thanks for contacting Fixya
My Goodman heat pump doesn't blow air through the vents into the house, but the fan comes on when the thermostat is turn on for the air conditioning
Check first that
  • the air conditioning equipment is turned on,
  • the thermostat is calling for cooling, and that
  • the blower unit or air handler is actually blowing air through the ductwork.
Here are the details of what to check in what order if your air condtioner or heat pump doesn't start at all when you set the room thermostat to call for cooling:
  1. Check the Room Thermostat Temperature Setting: Set the thermostat to at least 5 degrees below room temperature. Our elderly mom has no patience with switches and controls. She regularly calls her air conditioning service company with a service request, sometimes late at night, because she has simply failed to set the temperature on the thermostat lower than the room temperature. Don't drive your A/C like our mother.
  2. Check that the Room Thermostat is set to "Cool" not "Off" or "Heat". If the thermostat is not set to "cool" it is simply turning off your A/C. If the thermostat display is blank then it's not receiving power (for modern digital thermostats). Check that electrical power is on at the air handler and to the the low-voltage transformer that supplies power to the thermostat.
    If the thermostat has power, check that when you set the thermostat temperature down at least 5 degrees below room temperature the thermostat calls for cooling. If it doesn't then check for broken or shorted thermostat wires anywhere between the wall thermostat and the control board at the air handler.
    You can easily eliminate possible thermostat problems as a cause of failure of the air conditioner to start by simply eliminating the thermostat from the picture: disconnect the thermostat wires at the blower unit's control board and instead connect the two thermostat terminals directly together with a jumper wire. If the system starts then the problem is in the thermostat itself or in its wiring.
    If the thermostat is working but the compressor condenser unit won't start, you could skip ahead
    to COMPRESSOR / CONDENSER DIAGNOSTICS but I wish you'd double check the remaining steps in this article first because there are some sneaky snafus listed below that might still be the problem.
  3. Check that electricity is on for the equipment. Check all of the electrical switches and controls that can turn electrical power off at the indoor air handler or at the outdoor compressor/condenser unit. There are more of these switches than you might guess. Here's a list of what to check:
    Electrical power switches and service switches outside by the compressor, inside at the air handler, and fuses or circuit breakers in the electrical panel. Don't forget to check that the access covers to the equipment are properly closed and latched. Otherwise a
    BLOWER DOOR SAFETY SWITCH could be keeping the equipment from running.
    There are several other safety switches and controls, both manual and automatic that can leave an air conditioner or heat pump turned "off" such as a blower compartment door interlock safety switch, an electric motor overload or overheat switches, and a condensate tray spillage detector switch.
    Some hard-to-find electrical switches on an air conditioner or heat pump could be keeping your air conditioner from starting, such as
    a FLOAT SWITCH on Condensate Tray that could
    be
    causing CONDENSATE PAN SWITCH LOCKOUT - condensate spilling into an overflow pan that uses a sensor switch can be enough to shut down your air conditioner.
    or
    a blower MOTOR OVERLOAD RESET SWITCH could be keeping a fan motor from starting.
    A bad or failed starter capacitor could also be leaving your system shut down, failing to start a blower, fan, or compressor motor.
    See CAPACITORS for HARD STARTING MOTORS
    Watch out: See A/C - HEAT PUMP CONTROLS & SWITCHES to be sure you have found and checked everymanual or automatic electrical switch on the system.
  4. Check the electrical supply voltage. Even if electricity is on, if the supply voltage has fallen too far below the operating voltage range of your air conditioner it's likely that the system will not operate, particlarly, you may note that the compressor motor won't start.
    See VOLTS MEASUREMENT METHODS
Aug 22, 2017 | Goodman Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Coleman central electric furnace model#3400a816 heat does work ,blower does not come on .
does your fan on the thermostat when you turn it to on work? If not you have a voltage problem. Does cool work? Need more info.
Oct 23, 2013 | Heating & Cooling
2000 volkswagen beetle diaghram i need to know what all the pictures stand for on the fuse block, i need a picture
1-heated washer nozzle, heated outside mirrors 10A 2-turn signal system 3-illumination 4-license plate light 5-comfort system 6-central locking 7-buck-up lights 8-telephone system 9-abs 10-engine control-gasoline 11-instrument cluster, shiftlock 12-B+ for DLC 13-brake lights 14-interior lights w/ central locking 15-instrument cluster,automatic transmission 16-a/c clutch, electrical water pump 17- door lock heater 18-right head light , high beam 19-left headlight ,high beam 20-right headlight ,low beam 21-left headlight low beam 22-sidemarker light, right 23-sidemarker light left 24- wiper system, washer pump 25-fresh air blower, air conditioning 26-rear window defogger 27- daytime running lghts 28-fue pump 29-engine control, gasoline/desel 30-sunroof 31-automatic transmission 32-injectors 33-headlight washer 34- engine control 35-trailer socket 36- foglights 37-radiosystem 38-luggage compartment lights, central locking system 39-emergency flasher 40-dual horn 41-cigaritte lighter 42- radio system 43- engine control 44-heated seats74e01e3.jpg
Jun 27, 2010 | 2000 Volkswagen Beetle
Can I convert a propane furnace to electric?
Actually yes! You can install electric elements in the plenum that turn on by your thermostat. The convection blower from the furnace can be used. You can also install a heat pump system that will give you both heat and air conditioning.
Feb 10, 2010 | Heating & Cooling
Heat not blowing on heat cycle
Have to know what kind of heat it is, Gas, Electric or Electric Heat Pump.
Heat pumps, when air over air type, have an extra setting on the thermostat labeled Emergency Heat, Although these thermostats can work on the other types of heating as well.
Both modern Gas and electric furnaces have the blower controlled by a blower board. The flame and or heating elements can also be controlled by the same or a separate board. SO you could have a board problem, or a safety switch or other symptom causing a safety switch to trip off on you.
Consult with your diagram and find something you can recognize then trace the wires down and follow to where you get the power to turn on the heat (usually always R feeds thermostat and W feeds Heat). Colors of the attached wires means nothing at this point. Look for the terminal designations not colors.
Hope this helps you. Please grade me accordingly and GOOD LUCK. :)
Mar 03, 2009 | Ruud Central System Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Heating & Cooling Logo
225 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
