Question about Ionic Pro TURBO Air Purifier
Doesn't put out much air flow? is that normal?
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
Water filter
Check to see if you turned on the water to allow water to flow again if thats not it check to see if you put the fillter in the correct way you may have put in upside down. Good luck
Apr 11, 2014 | Manitowoc SY-1204A/B570 Air Cooled 1,205...
I have an alpine living air model xl15 it is mounted on my air return on my furnace not sure how it works it has a manual and a automatic switch what setting should i put it on?
You mean an auto and normal setting. I don't have a manual but I always use the normal setting. I don't remember what the auto setting does.
Feb 18, 2013 | Alpine Air XL-15 Air Purifier
Hi I've had my ionic breeze quadra silent air purifier for approximately 6/7 years. I must admit I haven't used it for approx 2/3 years as it does not light up. I changed the fuse but still...
Pull the element out and take a moist cloth and clean it out. After it is completely dry put it back in this should do the trick. If this helps please rate me and do a testimonial
May 17, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
Can't get the Honeywell F300e EAC back together.
there is a plastic cell key that keeps you from putting the cells in backwards. Simply reverse the cells and they should slide in fine.
I/O is the power switch, I think O is off.
Jul 18, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Ionic Pro TURBO Air Purifier Logo
43 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
