Question about Chatterbox Headset
LED Flashes red when power turned on
When turning on the Xbi2 plus chatterbox bluetooth headset, the LED flashes red and my smartphone won't recognize it.
  • Diana Askew
    Diana Askew Mar 22, 2014
    Problem solved. You have to be smarter than the device. My bad.
2 Suggested Answers
  • 130 Answers
SOURCE: my chatterbox xbi2h plus helmet headset will not flash blue so as to pair it with my iphone
Check battery for charge
Posted on Apr 30, 2014
Testimonial: "Thanks. so simple yet so frustrating thankyou very much"
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
Okay i have the mad catz 8806 mic it flashes red and blue and charges fine but i cant talk into it and cant hear anyone through it at all it beeps and i hear that.
If the headset you have is the Item No. 8860 in order to use it you have to pair it.
If you are using it on a PS3 then be sure that you have selected the headset in the PlayStation's settings.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Troubleshooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Hope it helps
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Trouble Shooting
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Trouble Shooting
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am unable to sync my Mad Catz bluetooth to my PS3 and I can't find my bluetooth manual. How do I sync up?
Please see the sync details below:
Trouble Shooting
Jan 28, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you get the ps3 to pick up the blue tooth head set
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Oct 22, 2008 | Philips VOX120 Wireless Headset
Chatterbox Headset Logo
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Shaun Baxter
Shaun Baxter
Level 1 Expert
John L radiodude365
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
