Ketron x 4
I JUST BOUGHT A KETRON X4 AND I CAN NOT GET THE MICRO OR THE VOCALIZER TO WORK???
  • LENNY
    LENNY Mar 23, 2014
    AS I SAID IN MY EARLIER POST,I GET NO SOUND AT ALL WHEN I PLUG THE MICRO INTO THE FRONT OF THE X4
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
When I start powerr-up 3 propellers turn in unison but one prop only starts to turn when the power is almost at full power
I youtubed your Model: X4 H107 RC
All propellers are in unison. Your model may be faulty.
All videos I have found show all 4 propellers working at all times.
Check the one propeller and see if there is anything obscuring it's rotation. Otherwise contact the store or the manufactuer.
Aug 05, 2014 | HUBSAN The X4 H107 R C Micro Quad Copter 2...
Disk to fat converter
Your hard drive via USB connection did not power on your hard drive so your PC can't detect the drive. I don't believe the cause is your software. Try another UBS port, if that doesn't work power down your PC, connect your drive and boot up to see if the program detects the drive.
Nov 05, 2013 | Computers & Internet
No mic coming though on vocalist live 4
Sounds like the mic you are using requires "Phantom Power." This means, you will likely have to purchase an external unit for this power (+48V) power to the unit. I use a Behringer Ultra-Voice Pro for mine. Works great!! You can find these on Ebay at a steal!
Jan 13, 2013 | Digi-Tech Digitech Vocalist Live 4...
Amp problems
please clarify.....do you mean that there is no audio ???? no vocals (only instrumentals) is hard to believe??
May 27, 2012 | BOSS AUDIO SYSTEMS CX650 4-Channel Car Amp
S/No: DR14B98-NMPMSL9-MM7WT66-8D884F8-TBVHS Plz send the activation and installation code for Corel X4 Email: tejaswi_kadialas@yahoo.com
10 Simple Steps to crack corel X4.
Step 1 : change the date 2010 to 2009
Step 2 : install the corel draw x4
Step 3 : download the keygen from http://www.filestube.com/e94732d7504edf0a03e9/go.html
Step 4 : extract the zip file of keygen
Step 5 : open the 'corel draw x4 keygen' folder
Step 6 : open x4 keygen
Step 7 : in keygen press 'key code' button and copy the serial no.
Step 8 : then open the corel draw x4. paste the serial no. (ctrl+v).
Step 9 : click on the phone corel and copy the installation code and go to keygen and
Step 10 : paste the installation code then click generate button and copy the activation code the go to corel darw and paste it the click finish
IT WORKS......................
Jan 04, 2011 | CorelDRAW Graphics Suite X4 for PC...
I bought a Samsung AVR720 almost two years ago as well as a new Samsung blu-ray machine - to match our lovely Samsung series 6 TV (which our friend - who reviews all sorts of equipment - said was a really...
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
Mar 05, 2017 | Samsung Televison & Video
Can any on provide me a activation key for corel draw x4 ..i couldn't update the corel draw... i had downloaded from torrents if it works i will rate 4..
I too am having hard time activating my CorelDraw X4 downloaded from a torrent site.
I have to give you heads up to resolve your problem. Get the keygen from CORE for x4 SP2.
I had installed X4 on 6 PC using CORE.
Just be patient though.
Hope this helps.
Mar 23, 2010 | Corel DRAW Graphics Suite X4 for PC
Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
Apr 03, 2009 | Logitech Z-5500 Computer Speakers
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
27 people viewed this question
 Grubhead
Grubhead
