Question about HP OfficeJet Pro K8600 Printer
Fax only dialing, not connecting
My fax will dial correctly and I hear ti ring and ring, but it rarely will actually connect to another fax even though the other end says their fax is working.
  • Brenda Kakehashi
    Brenda Kakehashi Mar 22, 2014
    I have AT&T U-Verse. The only fax to ever connect was to my ex-husband's fax machine. No other fax has responded to me sending a fax, although I CAN receive faxes.
    Problem Solver:
  • 13 Answers
Can u reset it to defalt QC Wireless
Posted on Apr 10, 2014
ctf1800
  • 4402 Answers
SOURCE: Fax not answering or receiving
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=391194&rule=44610&lang=en
Visit the HP Support and Drivers Home page .
Posted on Jan 24, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
SOURCE: I can not send or recieve faxes. Ran fax test
you need to find a telephone with 2 conductors and not 4. I tried it and it worked. Cable phone service does not use VOIP it actually uses services similar to the telephone company. Instead of converting the analog signal of the phone somewhere down the street at the switch it converts it to digital at the cablemodem and sends it at different frequency on the cable. It then goes to the cable company and hooks into the regular telephone system.
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Posted on Jul 21, 2010
Why is there no dial tone?
Connect a telephone in place of your fax machine. Listen for a dial tone. If you hear it, something is wrong with your fax machine connection.
Aug 15, 2015 | Brother IntelliFax-4100e Fax
When I try to send a fax, I hear dialing and beeping and then I get a message that says "No response".
It means there is no answer or connection on the other end. A couple of things could cause this: if your telephone connection runs through your cable company, the fax machine may start dialing before the dial tone actually begins, resulting in a call that's not completed. For this, you may have to dial manually instead of scanning your fax and then letting the machine do the work. Or, the fax machine on the other end is not set up correctly. For that, you'd need to call and verify your recipient does not have issues.
Jan 13, 2011 | HP LaserJet 3055 All-In-One Printer
Jul 21, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Oct 21, 2008 | Canon FAX-B820 Plain Paper Bubblejet
BROTHERINTELLIFAX775
TO NO MANUAL,
WHEN YOU DIAL A FAX NUMBER, AND IF YOU
HAVE DIALED IT CORRECT, YOU NEED TO
WAIT UNTIL YOU HEAR A COUPLE OR A FEW
DIFFERENT "CONNECTION" SOUNDS, AND
THE LAST SOUND IS THE FAX IS CONNECTED
TO THE FAX NUMBER DIALED SOUND.
IF I AM CORRECT, THE FIRST SOUND IS
A LOW TWEET LIKE SOUND, THE SECOND
SOUND IS A HIGH PITCH TWEET SOUND,
AND THE THIRD OR FOURTH SOUND IS
THE FAX SOUND, WHICH IS A SORT OF
STATIC-LIKE WHISTLING SOUND.
WHEN YOU HEAR THE FAX SOUND, THAT
IS WHEN YOU PRESS THE SEND FAXCIMILE
BUTTON.
I HAD A SIMILAR PROBLEM WITH A FAX
MACHINE ABOUT FOUR YEARS AGO.
IF THE FOREMENTIONED INFORMATION
DOES NOT HELP, YOU MAY WANT TO
RECONFIGURE YOUR FAX SEND AND
RECEIVE SETTINGS. REFER TO YOUR
OWNER'S MANUAL FOR TECHNICAL
DATA.
GOOD LUCK.
FROM
TEXASDUDE2008
Mar 12, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Intellifax 4100
Press speaker can you hear dial tone?
Try ringing you mobile from fax does it ring?
After dialing correct number with (outside line prefix if required) press start
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
INTELLIFAX 2820 NO FAXES COMING THROUGH
Oops, I disconnected from the chat with you after I said I would stay connected. If you have any other questions, feel free to ask them here. Just for our knowledge base, in case anyone else has this problem - it turned out to be a short in the phone line. When picking up the handset connected to the fax machine, there was no dial tone. When connecting the fax machine to another phone line, the dial tone returned. After swapping out the phone cord between the wall and the fax machine to be sure that wasn't the problem, Jriedel is now talking to the phone company about it.
Sep 12, 2007 | Brother IntelliFax-2820 Laser Fax
HP OfficeJet Pro K8600 Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
