Question about Radio Communications
Cp200 Sorry for my bad english my mother tong is french but my question is about a radius cp200 I dont ear anything when I push the talk button do i have something to press on to ear the beep when im pressing the talk button thanks :)
    Sergeant:
  • 223 Answers
Can you increase the volume? did you try the morse code button beep beep? are both units on? 10-4 big daddy truck nuts Over and Out
Posted on Mar 22, 2014
eradiostore
  • 1654 Answers
SOURCE: Motorola CP200, radio just beeps when im pressing any button.
It is possible your radio is not programmed, or has a bad/old battery.
It is normal for the side buttons 1 and 2 to beep when depressed to indicate you turned the feature on/off. Each of these buttons has the ability to be programmed a long and a short press feature.
If your radio beeps when your press the PTT button, on any or all channels, it indicates a low or nearly dead battery. Check your battery date code to see if the battery needs replaced.
If your radio emits a long tone on a channel, that channel is not programmed to function.
If your radio beeps a single beep when you turn it on, this is normal.
Charge your radio completely overnight, with the radio turned off. See if this solves the problem. If not, try a new/different battery to see if it will solve the issue. If not, drop by your local dealer and let them look at the unit.
Posted on Dec 16, 2008
SOURCE: Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Posted on Dec 31, 2008
eradiostore
  • 1654 Answers
SOURCE: Radius CP200 is in monitor mode I think and i
Your programmable buttons can be programmed to a number of options. Typically the first button is programmed to monitor and sticky monitor. If this button has been held in a long press you can clear the setting by holding it in another long press to shut it off, or by simply shutting the radio off and turning it back on.
Your second programmable button could be set for an number of features, but like the above description, simply pressing it again or shutting off the radio will turn the feature off.
When you refer to Monitor Mode, we assume your are indicating the radio is operating open squelch, with no private line code. This is when you can hear ALL transmissions on your frequency. If this does not describe the problem you are having please repost another question.
Posted on Jul 16, 2009
Goofguyster
  • 379 Answers
SOURCE: When I press the PTT button it will not beep after i talk
either that or take out the batterys and it will reset ist selft
Posted on Sep 22, 2009
eradiostore
  • 1654 Answers
SOURCE: When I press the push to talk button on my
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Posted on Nov 02, 2010
Is Radius cp200 compatable with rdu2080d
If your model number starts with AAH50R... the answer is yes. The CP200 could be programmed to match your RDU.
Jan 30, 2014 | Motorola CP200 Two Way Radio
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Motorola radius cp200
Not any recalls on this product. However, here are a few tips which may help:
1) There are 4 types of CP200 batteries: Li-Ion, Li-Ion Slim, NiMH, and NiCD. Due to the differing thicknesses Motorola provides an insert which can be turned around to accommodate the battery (or batteries) you have with your radio. When you look at the charger you will see two plastic ears sticking up beyond the charge cup. When you squeeze these ears toward one another you can lift the insert up and out of the charger. Turn the insert around according to which battery thickness you have. Then snap the insert back into the charging base. Your battery should rest and depress the spring loaded charge contacts in the base.
2) The insert has rails which guide the battery into place. You can see on your battery sides there are grooves which match the shape of the rails. In the beginning when all parts are new you must be very purposeful to slide the battery into place, but as the battery and charger begin to have more use you will find it easier to slide.
3) The CP200 charger can accommodate a radio with a battery on it, or a battery alone. (Tip: Always be certain the radio is turned off while on the charger.)
4) The only issue we have every seen customers experience with the CP200 charger is from rough handling. An internal plastic piece which holds the charge contacts in place can be broken if users are very rough when putting the radio in the charger. This is rare, but is known to happen.
Hope this helps.
Best regards.
Jul 25, 2013 | Radio Communications
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
ONE OF MY CP200 RADIOS HAS A STEADY SQUELCH SOUND ON ALL 4 CHANNELS, HOW CAN I FIX THIS?
One possible problem is a bad battery. Try swapping batteries with a known good unit and see if the problem is solved. If it is not the battery, then your radio is likely in need of repair.
Best regards.
Nov 09, 2012 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Compatibility
If your CP200 has a model number beginning with AAH50R it can be programmed to match the RDU2080d. If your CP200 model number begins with AAH50K, then the answer is no.
The letter R in the model number indicates it is UHF, and on the RDU2080d, the letter U in the model name indicates it is UHF. Both of these radios are programmable, and could be reprogrammed to match one another, if both UHF.
Best regards.
Sep 20, 2012 | Motorola CP200 Two Way Radio
My Motorola Radius CP200 has lost all channels that was set by dealer is there a way to reset back to factory settings?
It is seldom a CP200 loses frequencies/PL code settings. It is more likely the radio has a bad battery or another issue. The only way to reprogram the radio is by taking it back to a Motorola dealer, as they are all dealer programmable only. Sorry.
Best regards.
Dec 18, 2011 | Radio Communications
The phones won't ring. One is on "do not disturb" And i don't know how to take it off. The other set is in french . I would like it back to english
  • HI TO SET YOUR RING TONE FOLLOW THESE INSTRUCTIONS:
  • Press the "Off" button on your GE 2.4Ghz cordless phone to ensure it is not in talk mode.2
  • Press the "Up" and "Down" arrows on the base of your phone and choose "Ringer tone."3
  • Choose "OK" and then choose Ringer Tone.4
  • Listen to each individual tone and choose the one that pleases your ear by selecting the "OK" button. There are six available ringer tones to choose from.
  • TO SET YOUR PHONES LANGUAGE FOLLOW THESE INSTRUCTIONS:
  • Press the "Menu" key found on the front of the base of the phone and scroll with the "Up" and "Down" buttons to "Language."
  • Press the "Menu" key again and select the language you wish to use with the arrow keys. Choose from English, French or Spanish. Once you have decided on the language preference press the "OK" button
  • THANKYOU
  • Dec 18, 2010 | Uniden Cordless Phone
    Radio Communications Logo
    81 people viewed this question
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
