Question about Hardware & Accessories
Internet connection facebook connection
Want to connect chat to facebook, and it says that it is not connected
Hello, First reboot your device and make sure you are connected to the internet. You need internet access to login. Go to www.facebook.com and click log in and put your user name and id to get into facebook.
Sep 27, 2015 | Facebook Social Network
When I try to connect to facebook I get the message that im not connected to the internet. but my laptop is connected to internet
Try connecting to a different website. If unable to connect to other sites it is your internet connection which is the problem. If able to then problem is with Facebook.
Mar 26, 2015 | Facebook Computers & Internet
Why can't I log into facebook?it keeps saying check network connection.what's the problem?
Then you are not connected to the internet. On your computer you should check your internet connections. Either on settings or main menu.
Sep 10, 2014 | Facebook Social Network
Error -118 when loading url https://www.facebook.com/
may be your internet connection is slowor you may not be connected to the internet check your internet connection
Jan 05, 2014 | Facebook Social Network
Internet connection mobile pc
Facebook right? For the tracphone you'll need to find out if your phone has internet service, so then you could surf the web for facebook. For a PC, you just need to get an internet connection to connect to facebook.
Aug 11, 2013 | LG 500g TracFone
Can't chat in facebook
Most of our internet cafe customers problem when the internet connection is bad is that they wouldn't be able to chat in Facebook. So, my advice is check your internet connection because it's likely that it's the cause why you can't. You reboot your PC and your modem (un-plug and re-plug your internet source). Try other sites as well to see how the refresh rate is. If it's too slow then we can conclude it's your internet connection that causes it. Maybe then you should wait 'til it goes back fine. You may also try other browser.
Jan 08, 2012 | Facebook Social Network
The connection has timed out The server at www.facebook.com is taking too long to respond. The...
You are using internet connection with bad speed in that case you have three option :
1.checkout your internet connection and talk to you internet guy and also change your internet and wifi password so that no one can theft your internet data and get 3g or 4g speed connection.
2. get you computer or laptop format in case of malware or virus problem.
3.download facebook lite for lower data consumption. Connection has timed out Firefox Solved Closed
centain link for help.
May 22, 2017 | Facebook Social Network
I log into facebook and keep getting a message internet not able to connect operation aborted but no problems connecting to anything else. been happening for days now
This is probably due to your internet connecting then disconnecting due to poor connection, which is especially possible if you are using the internet over a WiFi connection. This would not cause a problem on most websites because the internet is built to handle unsteady connections, but Facebook has built there own software to not connect if this happens.
The best solution would be, if you are using WiFi, to get closer to the router or to upgrade your router. If you are not, you should contact your internet provider.
Feb 27, 2011 | Facebook Social Network
I cannot log in, they were telling me diagnost internet connection and it will show the facebook attemps log in
most likely an issue with your internet connection or the facebook server. Try to clean your browsing history and cookies, restart the system and make sure your internet connection is working, then try to connect to facebook again.
Sep 03, 2010 | Facebook Social Network
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; WWTClient2; .NET CLR 3.5.30729; .NET CLR 3.0.30729) Timestamp: Wed, 2 Dec 2009...
Within Internet Explorer, click Tools, and Internet Options, and then delete all temporary Internet files. Close Internet Explorer.
Re-open Internet Explorer.
Is it just one person's FACEBOOK web-page that causes the problem, or does the problem occur on *ALL* FACEBOOK web-pages?
Does the problem occur *ONLY* when accessing FACEBOOK web-pages?
If you're using an older version of Internet Explorer, upgrade to IE7 or IE8.
Dec 02, 2009 | Microsoft Internet Explorer 8
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
