Question about Thermo Scientific SC 100 Digital Immersion Circulator, 100C w/cla
Temp safety fault
We check the limit hight, the limmit setting and fluis select and continuos con the same issue
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 18, 2017 | Heating & Cooling
I have a Kenmore Dryer Mod#110 62722101. It will run about 10 minutes and shut off, after a cool down period it will restart but only run about 10 mins. Heats, fine, tumbles fine. A few days before this...
If it runs after a cool down period, then the high temperature limit is part of the cause. What is causing the high temperature limit to overheat is next.
Strong stream of air should be felt coming out the exhaust, make sure this exhaust air works or the burner part will overheat and cut out the flame/burner on hight temp safety.
With good exhaust air varified, the drying air operating temperature sensor needs to be checked, this cuts power to the burner. The sensor must open electricaly when satisified on temperature and should be properly mounted for proper sensing of temperature.
Bottom line: Check the hot air and its control
Jun 04, 2017 | Dryers
After driving for about 4-6 hours the temp rises
You should have your a/c system ck'd. Reason could be excessive system pressure and temp. This would explain the a/c safety turning off the a/c and the temp rise of the engine cooling system. Good Luck.
Jan 26, 2010 | Land Rover Defender Cars & Trucks
I can't download or do anything unless administrator and I can't change to the administrator
You can generally right click on a program and select run as administrator, try to start your browser by right clicking on its icon and select run as administrator. That might help.
Dec 17, 2009 | Computers & Internet
GOODMAN GMS9 limit switch
check the temp on the switch.Any switch will work as long as it has the same temp setting.
Oct 30, 2009 | Goodman GMS90703BXA Heater
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Compaq Presario c500 is quitting when hot
nope ...the problem might be from bios...it has a setting to power of when it gets to a certain temperature ...(CPU temp limit ) just ask for someone whom knows to set it ...and will be fine ...the other issue it might be the fail of your cpu cooler...and the temp exceeds normal values and its shutting down as a protection...when it gets to the maximum temp allowed. .So! just check first if it has a limmit around 70C or so ...and remove the limitation from bios...CPU settings..I dont know exactly cause there are a lot of bios variations...but when you will see it you wil know what to do .....good luck!
Apr 03, 2009 | HP Compaq Presario C500t Notebook
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Thermo Scientific SC 100 Digital Immersion Circulator, 100C w/cla Logo
48 people viewed this question
Top Thermo Scientific Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Thermo Scientific Health and Beauty Expert? Answer questions, earn points and help others
