I have a Life Fitness 95xi. Today I was using it set on level 8 (quick start) warming up. At the 10 minute mark I adjusted up to level 12. As soon as I started adjusting up all the resistance went out of the pedals and the display constantly beeps (while pedaling) and going back and forth from pause to resume. The faster I pedal the faster the switching back and forth from pause to resume. I couldn't get any of the programs to work after this. I would appreciate any troubleshooting help. Thanks, Jeff
SOURCE: Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
The resistance depende of it.
sincerely. God bless you
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
