Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio washer with a SD code
Just had control board replaced , due to the F1 code, 90 days later now a SD code comes up and now it wont spin on drain cycle
jyackle5
  • 8197 Answers
SOURCE: code sd on cabrio washer
The sd code means to much suds. You need to get a bettter he detergent.
Good Luck and Please rate FixYa!
Posted on Dec 20, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
  • 240 Answers
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
  • 171 Answers
SOURCE: Washer will not spin after draining.
the long drain code means that either the pump is bad or there is an obstruction to the water flow.  check the hose going to the washtub and also check for obstructions in the hoses at the pump itself.  if clear the pump is probably bad.
Posted on Aug 03, 2010
Y whirlpool cabrio washer is showing code 5D how do I fix
SD is Sud lock, too much soap, or clogged drain pump. Also check the pressure tube, make sure no gunk is in it. If none of that works, then replace the main control board.
May 23, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer no longer spins
Most likely control board. On a cabrio main power controls everything. If it agitate and drains and does not spin that's what it will be especially if there are no codes. Only other thing that could prevent spin, is a bad lid lock. But if there are no codes it a board.
Apr 05, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool wtw7600xw0 washer come up with a sd code
if the machine drain properly,,and you use HE detergent,you need to change your main control board...
Feb 19, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio Washer Model # WTW5600XW1, When placed on normal wash cycle, washer skips the drain and spin cycles, and no error code flashes?
If the same fault comes on other programs then it can be due to the controller board.However you can check the drain filter and pump , check inlet water flow to the drum and also check if the water level sensor is working to the set level.
Jan 23, 2013 | Whirlpool Washing Machines
Washer comes out of wash cycle stops code ol.run in rinse/ drain cycle,ol stops before comple cycle ,run in drain spin compels cycle
I hate to say it but everything on those machines is controlled by one board which can become faulty at any time. I would replace the control board
Sep 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a WTW6400SW2. Always get 5d code if we use high spin speed or do large load. Also seems to take forever for tub to drain. Related problems? In the past have epoxied exterior of drain pump due to...
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Sd 51
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button
In addition to the above tips, check the installation of the drain line. Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board. You will probably need a technician to diagnose and repair one of these component failures in your washer.
Aug 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Oct 20, 2009 | Whirlpool Washing Machines
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Washer LD error code
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Oct 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
