Question about Mitsubishi MSH09TW Air Conditioner
The remote control receiving secton stopped working.
800 30 70 T
  • Pedro Pavao
    Pedro Pavao Mar 23, 2014
    according to the technical report, the infrared internal unit stopped working. The part needed is the one i described in previous message (8003070T)
Both car remote controls stopped working
The receiver probably just needed resetting and reprogramming. I am surprised three are working - normally the receiver will only allow two.
Jun 29, 2017 | 2007 Pontiac Grand Prix GXP Sedan
Remote control not working
Hello
Try to repair the remote control. Without remote control, you can't access most of the tVs functions. Many faults with remote controls are repairable. Just get ito this link. You can get repair hints of remote controls from here. OK.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
Dec 14, 2011 | Humax Televison & Video
I have a Marantz SR5000 receiver that stopped responding to the remote control. seems like the remote is working properly. The receiver also works fine besides the fact that it stopped responding to the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 22, 2011 | Marantz SR-5000
The remote just stopped working and it is not the battery. I was told that the code in the remote is not reading the code in the receiver, but I can't get to the receiver to sync them. Would a...
Your fan has problem on its control board and not on remote transmitter control. Thermal fuse is blown inside its motor to protect the windings. Check the control board, crystal oscillator failed, micro-controller failure. A universal remote control will not gonna control the fan.
Thanks for asking.
Jul 13, 2011 | Hunter Ceiling Fan Light Remote Control
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
lykohavi
Aug 05, 2010 | Harman Kardon AVR 35 Receiver
IR Remote Control Remote Control: The remote works for a second then stops but still...
I am sure that you got this resolved already. But here are some steps to walk through if you haven't gotten it resolved, or have problems again in the future. I enclosed a link, where you can walk through simple steps to get the remote working for the receiver box. You do want to make sure that you are in front of the receiver box for this process. Also, if you have not changed the batteries in 60 days, go ahead and change those out too if possible.
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
May 17, 2010 | DISH Network IR Remote Control
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
Remote control won't work
Could need a new ir sensor or repair solder connections on the display (ir) board. You can check that the remote is putting out a signal by viewing it with a camcorder, turn the camera on look through the viewfinder and point the remote at it push a button. If it is working you will see a flashing light on the remote.
Feb 08, 2009 | Sony STR-DE197 Receiver
Remote Control stopped working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Otherwise the problem will be with the remote sensor or related components of the device.
Aug 27, 2006 | Toshiba SD-H400
Mitsubishi MSH09TW Air Conditioner Logo
22 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
