I have tried to connect an internal monitor on my laptop and when I did so the wire of the screen started to smell and smoke came out of it I quickly disconnected it and I saw there was some black mark on the metallic connections on the laptop monitor input Then I connected an external monitor and it works like a charm The wire of the monitor is black and toasted What chances do I stand that the monitor input on the motherboard is ok? I have not bought a new internal monitor yet
  • Iron Fist
    Iron Fist Mar 30, 2014
    It works like a charm guys! Only the old monitor has been toasted!
    Sergeant:
  • 223 Answers
KENTUCKY FRIED CHICKEN
Posted on Mar 22, 2014
  • Iron Fist
    Iron Fist Mar 22, 2014
    Could you please try to post a more serious solution if it is not too difficult for you?
ceezer
  • 20 Answers
SOURCE: how to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Posted on Jul 08, 2008
moncapitaan
  • 78 Answers
SOURCE: Gateway M305CRV screen black after XP Pro install attempt
Do you get any lights on the laptop? M
Posted on Aug 21, 2007
silveradoman
  • 58 Answers
SOURCE: External Monitor connection issue
There is only one way to connect an external monitor to a laptop.Most laptops have an "FN" key. by simultaniously pessing the "FN"key and F7 key it toggles from laptop to external to both each time you press the keys.
Posted on Mar 25, 2008
SOURCE: Dell inspiron 6400 screen problem
I had the same problem. You need a new graphics card.
Posted on Jan 29, 2009
bob_computer
  • 3153 Answers
SOURCE: connect broken laptop screen to external monitor
I would back mothmans answer 100% but might suggest you re-assemble the display to the laptop if you continue to have problems getting an external display going.
Posted on Sep 07, 2009
Why does alarm activate when there is no smell of smoke or fire not a battery operated unit 120v hard wired unit
The unit probably needs replacing (every 10 years by code for 120V smoke alarms; NFPA 72). Note that most 120V devices are of the ionization type and must be disposed of appropriately. The label on the under side of the device often has instructions. Also try searching for your model on the manufacturer's website.
Sep 15, 2014 | Home
When start up the secreen becomes wight
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Computers & Internet
My acer laptop show white sceern only?
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope it helps
Jan 23, 2013 | Computers & Internet
White screen appears on computer at startup
Jan 15, 2013 | Microsoft Windows XP Home Edition
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Heard a pop and screen went black
most likely an internal component. to further isolate it, try using another video cable to connect it to the computer, test it on another computer and try another monitor on your computrr. if the monitor fails even with a different cable and computer, time to get it repaired or replaced if under warranty.
Dec 21, 2011 | Dell UltraSharp 2407WFP 24" LCD Monitor
Ma acer aspire 5738z does not start at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 16, 2009 | Acer Aspire 5735 Notebook
My laptop monitor is not woking
Oct 16, 2009 | Computers & Internet
What I stated about the green on light and the fan is all that is happening. There is nothing on the screen, I cannot get anywhere. Nothing happens other than the green on button light an the fan. when i...
sounds like your video card or on board video is out....checking the monitor connection on a laptop is one of the first items the system checks for, and if it's out, then you wont get anything, the other problem it has the same tsymtoms your describing is the hard drive is out, and if it is, the only thing that works is the power to the fan, all other intelligence of the puter is not there, if you have another harddrive, exchange them out and see what you get, or ask a friend to use his, you just need to make sure it's the harddrive or the monitor, you'll get an answer oneway or the other, another thing you can do, smell the harddrive and check for even the slightest smell of burt hardware, then smell the internal area of laptop,or the video card, if the smell is there you'll know,it's very distinctive, there's no missin it.......hope this helps hun....shia
Apr 19, 2009 | Toshiba Satellite A135-S2386 Notebook...
Dell Latitude
If the system still works on an external monitor and functions normally otherwise, you might be able teo replace the LCD assy for about $150.
If the system no longer works on external either, then I'd say the system is no longer viable as an item to repair as it will be cheaper to replace it then to repair it. (New laptops start at around $500)
Feb 08, 2009 | Dell Latitude CPX Notebook
Computers & Internet Logo
David Payne
David Payne
