Question about Acer Aspire 5740-6025 Notebook
Shuts down to black screen
For no reason screen shuts down to black and computer turns off except fan still running. I have to restart. This happens if I leave the computer for awhile. This has only started in the last couple of weeks. Also I am not all that familiar with the technical side of things. bebe
  • 4 more comments
  • Brad Brown Mar 22, 2014
    Hi Barbara , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?what version of windows? What was the last thing you installed?
  • Josh Hannegan
    Josh Hannegan Mar 22, 2014
    Sounds like the computer is overheating. You might try cleaning it out with some canned air or somthing.
  • Barbara
    Barbara Mar 22, 2014
    Thank you both. I am using Windows 7 Home 64bit. I am not sure how I should use canned air as I have said i am not very technical . Also should the fan be running all the time? I leave the computer on all the time as I cannot put it into sleep or hibernation but I can cope with that.
  • Josh Hannegan
    Josh Hannegan Mar 23, 2014
    Usually the fan will be on most of the time. It depends on how hot the computer gets so it will speed up or down based upon how hot it is.Does the underside of the laptop feel more hot than warm?
  • Barbara
    Barbara Mar 23, 2014
    Josh I have not checked although I must admit at times the computer feels hot and then I usually turn it off.
  • Josh Hannegan
    Josh Hannegan Apr 23, 2014
    I would listen for the fan. If it is clogged and not spinning that is an issue.
  • Acer Master
  • 3,320 Answers
Sounds like it is going into Sleep or Hibernation mode.
In Control panel go to Power options and see what the settings are.
Getting out of sleep mode is accomplished by pressing the power button once.
Posted on Mar 23, 2014
Testimonial: "Mileso, I followed your but going into sleep mode the computer instructions but the computer immediately restarted and in Hibernation it stayed off for about 1 minute and then resumed. I will take extra note when the black screen comes on again."
PrimeZ
  • 10 Answers
SOURCE: Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
Posted on May 07, 2009
kd6rhd56
  • 400 Answers
SOURCE: computer immediately shuts down upon starting
Ok Take out the battery and leave it out for about an hour. IN the time its out Run the laptop on AC power and then go to control panel, open power options, and remove the hibernation check, and the turn the system standby to never, then hit apply. Then turn you laptop off and re insert the battery. If you still get the shutdown where it wont run on battery, then you need to replace the battery.
Posted on Jul 15, 2009
Arius
  • 446 Answers
SOURCE: Acer Laptop runs but shuts off suddenly
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Posted on Aug 03, 2009
Testimonial: "You were right. The next time I turned on the Acer laptop I noticed the fan was not running at all. Sent to Acer repair work fine now!"
parrotheadpc
  • 2600 Answers
SOURCE: I turn it on. It beeps twice loudly and goes to a
Possible Virus and Malware
There is a good chance that you have a virus or malware that is keeping those programs from opening. It does not matter these days what security you have if the door to the web is opened. At the end of this are two links to programs that you should load up and run. The first is MalwareBytes Ant-Malware Tool, the other is Avast Anti-Virus 4.8, install these two and let them perform scans.
Run MalwareBytes first and perform a quick scan, when it finishes, it will ask you to post the results, when it does delete everything it finds.
Run Avast and install it, when it asks, go ahead and schedule a pre-boot scan of your entire system. This should get rid of most problems….
http://www.filehippo.com/download_malwarebytes_anti_malware/
http://www.filehippo.com/download_avast_antivirus/
Posted on Oct 31, 2009
  • 15 Answers
SOURCE: Fan makes a lot of noise, then computer suddenly shuts down
Your computer seems to be overheating. Probably the heat sink or air path to the CPU is dirty, or you have a hardware device making interference with the air path way. You may also have bad BIOS configuration try downloading and running core temp 1.0 google it. The program will give you recommended fan speeds and will tell you the temperature of the system. If non of this works, your computer is a SIMPLY lemon.
Posted on Dec 02, 2011
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
My acer aspire 5315 will suddenly turn completely off and must be restarted for no apparent reason. Anyone having a similar problem or know how to fix this?
Had a similar problem with my Acer Aspire 5100. I fixed it by removing my fan....cleaning it, then reinstalling. I might suggest taking it to a laptop repair store if your not knowledgeable in replacing a computer fan.
Mar 15, 2009 | Acer Aspire 5610-4648 Notebook
Computer shuts down with Flt. Sim 09
Hmm. Does the screen flash blue before it shuts down? And does it shut down or restart?
Mar 29, 2008 | Computers & Internet
Shutdown
There could be any number of reasons for this to happen. However, the most likey reason - assuming that it runs for a bit, and then shuts down - is that the heatsink/fan on the CPU is not working, or not installed properly. Once the CPU heats up to a certain point, it will shut down to prevent damage. Perhaps the CPU fan as gone bad, or is completely clogged with dust.
Feb 03, 2008 | Computers & Internet
Screen shutting down
Well, Gestion Alim is French for "Power Management." It means that your computer is shutting off power to the video using the ACPI power settings, probably stand-by or hibernation. Bring up the Power Management settings in your operating system (in Windows, it's the Display icon in the Control Panel) and change them to something more reasonable. If you want to disable them completely in Windows, change to "Presentation" and make sure that hard disks and display are both set to "Never" shut-off.
Nov 08, 2007 | LG Flatron L1750S 17" LCD Monitor
Unwanted Shut-off
First Charge up you battery while the computer is off. Once fully charged unplug the adapter and play the game...see if it shuts down. If not replace that ac adapter. If it still shuts down... Your unit is overheating most likely. When you play high tech games which cause the processor and fans to run harder once it gets to hot. And most times you can hear the fan running loud on your laptop. 1. check the system requirements on the game 2. Are you overclocking your processor, check your bios 3. Lower the graphics settings and features in your game.. see if it shuts down 3.Or while you are running the game do the follow hit ctrl, alt, del buttons at the same time. A task manager box will pop up. Click on the tab Performance.....what is your cpu usage? 100% if so it's running the proccessor hard. Now in the same box click on Processes, then user name, you will then see all processes that are running at that time. If you want to play the game off line...only!!! you can stop some processes from running. On the bottom right hand corner of your screen by the clock you will see icons that load up at startup. Right click the ones not in use, like virus scan, firewall, other background applications that are running by right clicking over the icon and exiting or closing the application. Now keep in mind before you go back on line you should restart your computer so your security software will reload. Other reasons would be internal cleaning, fan, heatsink replacements and so forth. Which may need to be performed by a professional repair shop. Now they do have a laptop colling pad which have worked for some people. Also these laptops can overheat quickly, do not sit them on beds, and your lap when using ventilation is important. And also you might still want to have that ac adapter checked out. If all else fail... restart you computer in safe mode...try running the game..see if it shuts down. Good luck with your games
Sep 15, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5740-6025 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
