Question about GE PSS26MGPBB Side by Side Refrigerator
No water from door on refrigerator
There is no water coming from the door of the refrigerator
    Habit-Forming:
  • 76 Answers
Change the in-unit water filter.
Posted on Mar 22, 2014
I have a whirlpool refrigerator side by side with Ice & water in door. I can't get water to come out. How do I fix it?
First make sure that the water line to unit is functional. then check out the solenoid that feeds the water to the door for operation. If it is not working there will never be any water appearing at door. And if solenoid is good the switch that sends it power may be non functional.
Mar 02, 2016 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water
It is fairly common for the water tube in the door to freeze. Remove the front grill at the bottom of the refrigerator, find the water disconnect to the door and disconnect one side of the tube. Most newer connectors just have a little ring that you push in and this releases the tube. Push the water dispenser lever for just a second and see if water comes out the tube. If it does then the tubing in the door is frozen. You will have to shut off the refrigerator off for a while and leave the door open so the tube can defrost. Push the tube back into the connector under the refrigerator and wait. after an hour or two water should come out the dispenser. Another possibility id this doesn't work is the water tank is frozen in the fresh food section behind the crisper. Again you will have to shut off the refrigerator and let things thaw out.
Aug 02, 2014 | GE GSL25JFXLB (250 cu ft) Side by Side...
Refrigerator trio water not coming out
the water actuator switch could be bad or the arm broken. The water line could be frozen in the door or the reservoir ion the fresh food compartment. the water valve in back could be bad.
Jul 15, 2014 | Kenmore 24.8 cu. ft. Trio French Door...
Door water dispenser not working
It may be the water line in the door is frozen. I have come across this several times. Check to see if the water is coming to the door by disconnecting the quick connector to the door behind the grill at the base of the refrigerator. If water comes out of the tube there then you will have to defrost the freezer door by leaving the door open for a coule hours.
Mar 22, 2014 | GE PSS26MGPBB Side by Side Refrigerator
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Instaled new water value no water toice maker or water
Remove the bottom kickplate and find the hose coupling . Push in on 1 end and slide hose out . Then close the door and push for water . If water comes out the hose in steady spray , then your complaint would be door is frozen .
Jul 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water coming from under door
  The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
Oct 25, 2007 | Kenmore 50522 / 50524 Side by Side...
GE PSS26MGPBB Side by Side Refrigerator Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
