Question about Lowrance LCX-25c GPS Receiver
My Lowrance LCX-25 colored won't turn on when I press the power button. The screen flashes then it goes blank, Why is this happening and can anybody help?
Why will it not turn on. The screen flashes like its going to turn on, but then doesn't. Somebody help!
4 Suggested Answers
CMV9
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
SOURCE: Stops on boot up
I downloaded an updated version of software from lowrance. Once i installed the software it came back working like new.
Posted on Dec 31, 2008
SOURCE: Lowrance LCX-27C has power but only opens to the
The LCX-27C will draw up to 1.5 amps when powering up, if that amount of current is now available, it will power down. Double check your power connections. The +12vdc supply must be able to also supply enough current. Once you get it to stay on you can temporarily shut off the transducer by going into full mapping mode, or switch it to sonar simulation and the current draw will drop considerably. When you are ready for the permanent installation run solid connections directly to the battery and be sure to use the inline fuse for protection.
Posted on Oct 01, 2009
It was staying on for about 6 hours then a blank screen. now it comes on to the startup screen and then goes to blank screen.
Same thing happened to my older model. Going to research it today. Mine was on a hot day and Matt have over heated. After recharging the battery it no longer comes on at all. Let me know what you find out if anything
Sep 14, 2015 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Comes on white screen then off just for a second
If possible, try to restore the device to the newest firmware on it using your computer using this firmware:
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-18C/Downloads/LCX-18C-Software-Update/
OR
Do a soft reset. This may resolve your issues and will also keep your data on the device.
Do a soft reset by:
1. Having the device already off
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If neither of those work, try a hard reset. This will however delete all stored data off your device.
To do a hard reset:
1. Have device off
2. Press and hold the ZIN&ZOUT Keys at the same time
If none of these work, contact Lowrance at 1-800-628-4487
Mar 05, 2011 | Lowrance LC X-18c GPS Receiver
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Stops on boot up
Dec 30, 2008 | Lowrance LCX-18C
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
Lowrance LCX-25c GPS Receiver Logo
98 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
