Question about Apex Digital Televison & Video
Apex HDTV board burned out
My 47 in. Apex HDTV only a year and a half old stopped working. TV Tech came out and showed me a burned out board. I'm not sure what the board does. Can the TV be repaired or is it a total loss?
    Top Expert:
  • Apex Digital Master
  • 36,279 Answers
Why not get a repair/replace estimate from the TV tech?
Posted on Mar 22, 2014
jerryg50
  • 1667 Answers
SOURCE: LN-S4692D 46 in. HDTV T-Con Board
This answer is generic:
Most of the time they use fuse resistors. Sometime there a number of them. They are not all the same. This is not a simple fuse. It is a resistor combined with a fuse. You would need the service manual to properly identify the fuse resistor and have its spec. You would then have to order the correct one from a parts distributor. If it cannot be replaced generically, the original would have to be ordered from the manufacture.
In any case, if there is a blown fuse on a power supply board you can be sure that there are failed components that are most likely shorted. This would mean that the board would have to be troubleshooted to find and replace the defective parts.
Most of the circuit areas and the boards in these sets are not supported to be serviced at the component level. They change the defective boards as in the same process as servicing computers.
As for the heat problem, if you can find someone who is technically very competent, maybe he can custom install a fan for the area that is getting heated. It should be possible to find a 12 volt source from the main power supply to run a small fan to assist for extra cooling.
If you have your set in a cabinet, or if it is wall mounted it may run hotter. We found that sets that are wall mounted tend to fail more often because the heat can reflect off of the wall back in to the set. Cabinets tend to not allow the heat to dissipate as well as out in the open.
Jerry G.
Posted on Jul 26, 2008
SOURCE: Crackling noise
I think I have solved the problem. I dusted the tv completely. Then took the cable box and with a hair dryer in the cool setting blew out the interior circuits to try to remove all dust. Turned the set on no more crackling. Thanks for the posting.
Posted on Nov 17, 2008
erleichda1
  • 7 Answers
SOURCE: vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: Vizio 47" Costco hdtv has red floating areas!
After posting this problem we did call Vizio. They sent out a repairman (had to wait over a week) who fixed it by: Replacing the LVDS cable and the main board. (Just like somebody on this blog wrote somewhere!) We also had just previously called our cable company who came out (also free) and checked our system only to find the cable running around the house to the tv needed replacing as it was sending zillions of errors. The red flowing problem (called "red pixilation") was due to the Vizio LVDS cable and main board being faulty from the factory.
Just want you out there in web land to know how to get your similar problem fixed!
Posted on Jun 14, 2009
trixoftrade
SOURCE: Screen displays bottom half of picture only
jfanellijr ..your plasma has overheat problems, not circuit or video board, use high compressed air to blow out all the dust inside the vent. Hope this helps
Posted on Apr 08, 2011
Le3242 white lines on screen
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Screen shots to fault LCD TVs are shown. You can see and determine about the fault to your TVs'.
Apr 02, 2014 | Apex Digital Apex 32 in. LED 720p 60Hz...
Lg plasma tv wont turn on
if the tv unit goes to safety mode after you turn on that was mean an error was detected. check for bad component parts at y and z sustain board.
Sep 15, 2012 | LG 50PG20 50 in. Plasma HDTV
I have an LG 47" TV (47LG50) that I bought a year and a half ago. It worked great up until now. I have three seperate HDMI ports (PS3, Cable and Blu-Ray.) It all off a sudden says "no signal" to all...
Tries reset the tv and cable box,by unplug,replug both devices about an hour later.Let the cable boot up and update it softwares.Goto tv Menu goto PICTURE,go down to reset.The Tuner board it reseting to the Factory setting.The HDMI hubs,should all works now.Not than,the tv Tuner board have problems,must be change.Tries Shopjimmy.com,Ebay.com to buy a refurbish a Tuner board for the replacement.
Jul 15, 2010 | LG 47LG50 47 in. LCD HDTV
Purple hue and no sound
Ur tv Tuner board,that the board where the incomming brocast signal cable connect to it.That the Tuner board,it defective.Replaced the Tuner board ur tv will functions normal again.
May 27, 2010 | Vizio SV470XVT 47 in. LCD TV
Picture looks almost 3-D
When convergence out ICs stop working in rear projection TV, picture looks 3D affects.
Need to test/ check supplied volts on convergence out ICs on main board and if volts are OK, replace both ICs.
I'm not sure if you are going to repair TV by yourself or will ask local tv tech to fix it. Let me know please.
Thanks.
Sep 14, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
47 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
