Question about Samsung Televison & Video
Gray bar on top only
Have a gray bar on top only 40 inch flat screen. can shades of picture in the gray
    Filmmaker:
    Uploaded 5 video answers.
  • 181 Answers
Hello, I will need a picture of the screen and a model number to be sure, but it sounds like it has a bad screen.....tks...Terry
Posted on May 25, 2014
rulds2008
  • 3866 Answers
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Posted on Nov 30, 2009
Testimonial: "i just hope this works"
  • 84 Answers
SOURCE: hdtv lcd 40 in. broken screen face
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
SOURCE: Picture is squeued vertically from top to bottom.
check for dry joints around the main chassis,esp the supply lines .
Posted on Jan 05, 2009
lukster
  • 217 Answers
SOURCE: our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
Posted on Dec 30, 2009
SOURCE: Samsung 40" tv won't turn on
i had the same problem, you'll have to call the samsung service center. You TV's part which looks after the voltage connectivity has failed. This majorly happens due to voltage fluctuations. The part will cost around Rs. 2800 and service charges will be applied by the company.
Posted on Jan 04, 2010
Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Nov 28, 2013 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
The right side of my screen at about 3 inches from the side has a vertical bar that is lighter in shade than the rest of the picture. It started as horizontal flickering lines contained in the vertical...
Hello
There must be some loose contact with the t'Con board of your tV. Just look for it. Just unplug and replugh all the strip wires goes to T'Con board. This must solve the problem to your Tv. OK.
Oct 13, 2011 | LG 42LC2D 42 in. LCD HDTV
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
Gray faded look on top to picture
It can be the anty polarizing plastic screen that protects the display.
Often it causes grey or reddish shadows, in that case must be replaced.
Sep 15, 2008 | Televison & Video
It can be the plastic anti polarizing screen that covers the display.
Often it causes grey or red shadows on top of the picture.
Sep 15, 2008 | Toshiba 56H80 56" Rear Projection...
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
90 people viewed this question
Henry  Thomas
Henry Thomas
