It is refurbished and is running xp pro...everything to the right of the mouse (withing the keyboard) does not work
SOURCE: HP elitebook 6930p webcam not working with skype
did you try to use web cam with another software like msn and see if it is working or not , if yes try to make skype identify web cam again by going to tools menu then options then choose vedio settings it will identify your cam automatically
by the way i love elitebook its amazing piece
SOURCE: HP EliteBook 6930P display brightness keys do not function
This sounds like an issue in the power settings, you can get to them through the display options (right click desktop, go to properties, look for power settings)
SOURCE: hp elitebook 6930p keyboard not working properly only some keys working
It need manual repair / replacement of the key locks !
Was the keyboard working properly when you got it?Keyboard faults are usually a result of spills.Sepage can even get to thekeyboard ribbon connection on the motherboard.Replacing the keyboard and ensuring the ribbon connector is clean is the solution for spills.Reseating the ribbon on the motherboard after checking for any possible shorting on the connection strips
Keyboards are usually easy to replace. It sounds like your might need replacing. If so then here's a video that will help you accomplish this:http://www.youtube.com/watch?v=Jqg5uyw7d...
Thanks for the advice....and yes the keyboard was working fine and then all of a sudden the right side just stopped working. However, oddly enough, I got so aggravated with trying different things with no results, I just shut the computer down and let it sit for about five hours. When I turned it back on, the keyboard is now working properly! Weird! Anyway, I appreciate the help!!
