Question about Kwikset Locks & Locksmithing
Moisture has been getting in the lockset, door is on a storeage shed that opens out ,to the weather. how to prevent this?
  • 2,760 Answers
Graphite grease costs about 5 bucks a little tube put on key and insert/turn several times , wipe key off with rag
Posted on Mar 22, 2014
Are there shorter latch bolts for kwikset locks
You may need to drill the hole in the frame deeper to prevent the bolt from bottoming.
Sep 21, 2014 | Kwikset Locks & Locksmithing
Moisture
A short burst of WD-40 or Triflow into the keyway, then insert and remove your key a few time. After that, insert the key and turn back and forth, it should smooth right out.
Mar 22, 2014 | Kwikset Locks & Locksmithing
Cannot enter user codes. shuts down before all digits are entered.
Sounds like either your batteries are dead or you have a wiring problem inside. First try replacing all the batteries in the lockset and see if that fixes the problem. If not remove the lockset from your door and see if you have any water damage inside. If you have water damage then you are getting a short in the lockset causing it to not open up. The best solution is to get a new lock unless you can find a place to fix the wiring on the inside. If you bought the lockset from Alarm Lock I think they might cover that on a warranty. If not I don't know. Check on that and see. When you go to install the lockset make sure to seal the outside of the lockset with either silicone, caulking, or any other water proof sealant. Water can be very lethal to electronic locks. If you need help on installing one I might be able to help as well.
Feb 25, 2013 | Alarm Lock DL5200 Trilogy Electronic...
2008 charger 3.5 weathers been cold and car parked all week. car wont jump to next gear ???
Moisture has gotten into the transmission and the ice crystals have thickened the transmission fluid. Either get it inside to a warm place or run an electric heater beneath the transmission to heat the metal and eventually, the transmission fluid. Once you get it to work, drain the old oil and replace the filter and the oil. Change both more frequently to prevent moisture buildup.
Jan 12, 2013 | Dodge Charger Cars & Trucks
Accidently locked my mums keys in her lancer after moving it into the shed. we have no spare key and she needs it to get to work as it would be a $100+ taxi fare and we are not in a financial situation to...
Got that same situation long time ago. The simpliest and cheapest that i did is break the quarter at the rear door so that I could reach the door lock and open the doors!
I have ***** the other parts, to open the door, by hiring locksmith that cost me a lot than buying a replacement glass, put a wire in the door that will break the rubber weather strip and paint. Force the door lock to turn, that much expensive to replace.
Its up you, when time and money is required to solve such situation!
Hope that helps you!
Thanks for using Fixya
P.S. If you know somebody in your neigborhood that cracks open cars, is much better!
Dec 08, 2010 | Mitsubishi Lancer Cars & Trucks
The Yale lock on my Front door in becoming increasingly difficult to open with the right key. I'm worrie dthat one day soon I wont beable to open it at all. What is wrong with the lock? Could I use...
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
Nov 17, 2010 | Garden
Cannot remove an old schlage door knob. There is a small hole on the underside of each handle. What do I need to do to get the handles off? I don't know name or item # but the page makes me choose one.
It is a small allen key (hex head) that comes with the lockset when purchased. They are just threaded into the handle (knob) and sets into a reset when threaded in. You can take some putty and push it into the hole and gently remove to make a negative imprint of the allen key, go to a local home center like Lowes or H. Depot and match it up. You can buy a set of allen keys that are like a pocket knife with multiple allen keys. Note, it is very thin. An alternative is to purchase another similar Schlage lockset, open carefully, use the key, and return the lockset saying it is the wrong one. Not nice to do, but in this economy every penny counts. I hope this helps and good luck.
Oct 24, 2009 | Schlage BE365-CAM BE365CAM505 Lifetime...
1999 ford taurus with moisture in the headlights
Most headlights lens are sealed up to prevent this problem. A broken seal or a crack somewhere opened up to let in moisture.
You can drill a small hole on the lowest part of the plastic headlight housing to let the water drain out. Or, replace the plastic headlight assembly with a new sealed one.The plastic headlights turn yellow and cloud up over time (not because of moisture inside, because it's plastic getting ruined by the weather and the sun). This problem reduces headlights from putting more light on the road.
The only thing you can do with moisture inside the headlights is to drain out the water that builds up. The seals on the headlights are bad right now and are going to keep letting moisture in. I would replace the both headlight assemblies for new sealed, clear ones.
Sep 23, 2009 | 1994 Ford Taurus
Door opens half way then closes quickly with electric operation sprayed wd40 on rollers but still not working properly
Sounds like the 9 volt battery is very low, please put in a new, fresh 9 volt battery and see if that helps, as you've already addressed any issues with sticking, etc. When the battery(ies) are low, some electronic locks don't have enough power to fully pull in the dead bolt and the internal spring can overpower the small motor and cause the lock to re-engage quickly.
If you're getting a flashing red light when you enter in your key code, followed by flashing green light, your battery is low, if you're getting a flashing red light, the batteri is critically low.
If you have recently installed this lockset, it is possible that the alignment is off and is causing the deadbolt to drag and is preventing free movement. You'll need to adjust the lockset to allow the deadbolt to move freely by turning the hand knob with the door shut all the way.
If that doesn't help, please contact Schlage directly by calling them at the numbers provided:
United States Customer Support
Warranty Information: 1.888.805.9837 All Other Inquiries: 1.800.847.1864 Canada Customer Support
Within Canada & US: 1.800.900.4734
Hope you find this helpful, best regards!
Aug 15, 2009 | Schlage Camelot Deadbolt Keypad, Satin...
Maytag french door bottom freezer (does NOT have water/ice dispenser on door). There is moisture on the door seal - the movable piece - which ends up dripping on the floor every time you open the door. ...
You have a seal problem around the door or the heat strip inside the frame to prevent this is not working. Or both. So you are sure the model is the MFD2560HES. Let me know if you want me to help you solve this, Sea Breeze
Jun 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
Locks & Locksmithing Logo
67 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
