Question about eMachines 15 inch Monitor
White screen woke up this morning with a white monitor screen on my T3302 emachines computer. I have tried unplugging the computer from the monitor and get a couple black flashes then back to the white screen.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Test your computer with another monitor, if same issue occurs, problem is on video card/cables of your computer, if it runs good on another monitor, old monitor has problem.
Posted on Mar 22, 2014
White screen showing on monitor
Sounds like you have a bad monitor.
Try unplugging the monitor for several minutes and re-connect.
Also, you may want to re-seat your video card on PC.
If you have another monitor to check your video with, it would help.
Hope this helps.
Mar 22, 2014 | eMachines 15 inch Monitor
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachines t3302 video controller
There are two drivers listed on Emachines support site. Try one and if it does not work, try the other. The computer probably shipped from Emachines with two different build of mother board.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1558
Feb 16, 2012 | E-Machines T3302 PC Desktop
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
I have an emachine T3302 and the screen is black help.
Emachines are not very reliable machines. Are you sure that the monitor settings are correct and that the chords arn't loose, otherwise you may have to get it repaired (good luck with their customer support) or replaced. Sorry.
Jun 06, 2011 | E-Machines eMachines Desktop PC
Where does the video card go in a t3302 model emachine?
This particular model have AGP expansion slot located on motherboard, as this is rather obsolete computer, I am not sure if this is financially viable solution.
You will need phillips screwdriver.
To proceed with upgrade:
1. Switch off computer,
2. Remove power cord and monitor cord, if you want, you can disconect all remaining cords as well, but only if you are moving computer elsewhere.
3. Remove two thumbscrews holding left side (grill) panel, then slide it back and lift off
4. AGP slot is located below processor, just above white PCI slots, it is offset slightly towards front of the computer. If there is little screen mounted in first hole, remove it, depending how it is mounted by either, removing of the screw, or breaking it from the case.
5. Orient your card and insert it firmly in AGP slot, card should fit snuggly without bending or excessive force. Use screw to mount it to the back of the case frame.
6. Connect all cables, monitor cable to new installed video card, start your computer and check if there is display, if you have BIOS display, switch off computer, you installed your video card correctly.
7. Replace side moving it in reverse to removal, hung it first on the top and then slide forward, secure it back with thumbscrews.
8. Start back your computer
9. Install video drivers and setup your display to desired resolution.
Enjoy!
If you need manuals and settings for this model, these are availbale at this acer site:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3302
Aug 06, 2010 | E-Machines T3302 PC Desktop
Emachine 786n mointor frozen emachine logo
Try a different monitor. Most likely your having operating system issues that cause the monitor to do this.
Also - try this - As you turn the machine on tap the DELETE key - this will take you to the DOS platform of the computer. If the screen changes to anything you have operating system issues. Try a repair with the original disk or the operating system disk that was last installed.
May 08, 2010 | Computers & Internet
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Emachine monitor with a HP computer
i am trying to hook up a emachine monitor to my compac computer but the monitor will not come on there is another wire coming off the part that hooks in the compac but there is nowhere to hook it can you help me?
Oct 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
eMachines  15 inch Monitor Logo
153 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
